XJSuperman
Happy Thanksgiving
Hey don’t forget about the Honda Odyssey in all of this. My wife loves hers and you can haul a lot of junk in one when you fold the back seats down and pull the middle row out.
We had a GMC Explorer Limited van growing up that we used exclusively for road trips. It had the turtle top, lay flat bed, captain chairs, built in TV (my dad hooked up a Nintendo in it so we could play games), had the star light headliner which back in the day was "fancy", that thing was like riding around in a lazy boy! I think ours even had a little refrigerator, I was pretty young so don't quote that part. They are definitely super nice. That's probably about the only van I would actually drive.
Ours had a beige transition paint job, kind of something like this.
Ugh, I feel your pain -- at least you got 'em working in the end!Over 50 bulbs burned on 2 strings, not sure what happened as it was only on those 2 strings but after way too much time stripping bulbs out of a string I had to go to HD to buy to then put into this one...it's working again
I've had 50 lights burn out at once a few times before -- my theory is that several of the lights burn out slowly, but the shunt resistors keep the remaining lights working. The voltage through the remaining lights slowly increases until the bulbs can't handle it anymore, and the rest of that series (of 50 bulbs) all burn out at once.
Thank goodness my wife's car doesn't need any of the mounts changed. However the passenger side on the Camaro is still waiting on me. The driver side took almost 4 hours and a lot of cussing!In prior activities before this most recent side quest...
Last motor mount came out
Old was in the best shape compared to new.... but as it was out and I had the new one... it got replaced
Installed
Did have to break out the big ugga dugga gun
Otherwise was straight forward. While under there ****** fluid got drained again(still waiting to be refilled) and the front differential/bevel gearbox got extracted and refilled thanks to the fluid extractor included in the fcp euro kit.
Filling transmission, then servicing the Haldex unit on the rear axle is on the list for tomorrow.
I lost this battle last year. Our tree was 12 years old. It had almost half the lights burned out and the wife had already added some new strands. So new tree and the plus for me is the box was a different size and fits in the shed better.Summoned on another side quest in the midst of one of my own
After bringing up the obligatory boxes and sorting thru totes in the storage nook under the stairs.....had just put the fill plug back in the front differential/bevel gearbox on the Volvo and my presence was demanded at the tree
At least 2 strings of lights out at the bottom....
This tree is 9 yrs old....very close to heading to the dump but the probably 300 dollar price tag now vs 50% off in 6 weeks is tough to swallow if I can get it back lit up
Bret
Bret
That ****** flush was a little more involved I see!
I hope my tree isn’t blown like yours we’re, but if it is can I send it to you to replace the bulbs?![]()
^Milwaukee has such a good variety of products that it's almost a no brainer to invest in their products. I've got the M18 hi-torque and mid-torque, then the M18 impact driver and M12 Surge impact driver, M18 and M12 drills, and the M12 Ratchet. Without a doubt they are great investments.
Thats wild you have to pull the pump to drain the fluid in the volvo?!?!?
That is a haldex unit, they are used in VWs as well, my old play car (R32) had a haldex rear end and it had a tiny little drain plug on the bottom, then the top hole to fill it with the tube (which if you are ever in a pinch, the VW power steering fluid will keep you on the road, both are a mineral based fluid)
Either way, thats a bummer you had to pull the pump
Ha! I've tried this before too! My wife is well aware how much I've saved us over the years doing things. I do farm out a lot of car repair but happy to replace our brakes in a couple of hours and save $300+ each time.Slowly trying to keep progress on the light switch swap-a-roo as I have time/energy. Getting closer....slowly. The wife got a bid the other day for a clients project of around $1700 customer cost to supply and swap around 2 dozen fixtures/receptacles and also swap wall sconce fixtures and a ceiling fan (light fixtures provided, electrician labor only). I then tried to leverage that as a justification for how many $$$'s should go into my tool budget given I was doing fixture swaps with higher dollar switches....I got nowhere with her on that one....drat
At the advice from someone on a woodworking forum I created a spreadsheet of the woodworking projects I've built and found a comparable product, not Ikea, with a price online. The total was pretty amazing considering I haven't made all that much.
I had that m12 stubby in my cart, but waited too long to order, well that and the m18 circular caw with 8ah for 199.
Both were sold out by the time I went to submit the order.
Logan do you have any scanners that will show you realtime info? Quick easy way to see what the O2s pre and post cat are reading.
I've had TorquePro on my phone for years, it's been worth every dollar. $30ish bucks all in for the app and the OBD2 BT reader.
Has worked on all GM, Ford, & Toyota that were OBD2 compliant in my stable.
Ironically that saw was also in my cart for awhile. I was still debating on it a couple hours later and had the same out of stock message
Speaking m12, I have the high speed ratchet which is handy as well.
What I love the most is the "gun" looking drill. Super handy around the house.
This one:
Milwaukee M12 FUEL 12V Lithium-Ion Brushless Cordless 4-in-1 Installation 3/8 in. Drill Driver Kit with 4-Tool Heads 2505-22 - The Home Depot
Lend a fantastic addition to your toolbox with this Milwaukee M12 FUEL Lithium-Ion Brushless Cordless 4-in-1 Installation Drill Driver Kit with 4-Tool Heads.www.homedepot.com
I may have missed it, but why did you have to replace the motor mounts?
As a reminder, I previously mentioned the O2 sensor on the Volvo. I think you will find that to be the issue. As a matter of maintenance, you might just replace them if it's an easy job anyway..... remember....RockAuto is your friend![]()
This one:
I over compensated and ordered the mid tq 1/2" and compact 3/8" with 2 6ah batteries, then added the sawsall with 8ah instead of the curcular saw. Of course that was before I ordered the circular saw with free 8ah at the sale ($50 higher) price, the track saw with 6ah in a packout box, a couple packout bit sets, another installation drill and the gen 3 m12 drill/impact set. Of which I have gen 1, and gen 2 already..
I may order a couple more 1/2 and 3/8 kits as Christmas gifts. Under $350 for 2 impacts and 2 6ah batteries is still a solid deal (imho) not as nice as the stubby m12 with 500ftlbs for 159 though.
I have the m12 stubby but it's the older gen. It struggled to do a lot of the things I wanted it to do. Which was a shame cause the footprint is so good on it! I have the m18 mid and high tq ones also to fit all the gaps.
I fully committed to the 12/18 line..... the lawn tools are great. Id like some the power ratchets but I keep saying would I use them?
Looks like Depot still has some sales on Red going...
Milwaukee M12 12V Lithium-Ion Cordless 3/8 in. Ratchet and Screwdriver Combo Kit (2-Tool) with Battery, Charger, Tool Bag 2401-21R - The Home Depot
Complete your fastening applications with this Milwaukee M12 Lithium-Ion Cordless Ratchet and Screwdriver Combo Kit with Battery, Charger, Tool Bag.www.homedepot.com
This is a very bad time of year for me but I made it through Black Friday and Cyber Monday without taking even a sip of the red Kool-aid. Didn't even attend a meeting!I'll be returning the M18 set and keeping the smaller 3/8" M12 impact. It'll do everything I need to do plus some while preventing battery platform scope creap
@Blackbyrd, I felt the same way and I don't use mine all that often but when you have to remove a long bolt in a tight space (belhousing?) you'll be thrilled to have it. It's on sale at the moment:Id like some the power ratchets but I keep saying would I use them?
That is a great idea!Absolutely plan on my Brother Labelmaker getting a solid workout as I transition hardware around. Right now I'm thinking I'll label all the individual bins first with basic adhesive labels, but will try and label the drawers with magnetic backed labels so I can move the labels around as I change my mind on what stuff belongs in what drawers
