4 Barrel barn build.
Woodboxkiwi
Hey there team. Long time lurker, first time poster. Tomorrow I have 2 truck loads of lumber and poles arriving to start the construction of my forever shop.
So far we have done a bit of excavation, permit gaining, planning and ordering. It is mid winter here on the other side of the planet so hopefully the dry winter we have been promised stays on track
We bought the property Nov last year and immediately began scheming to get the build underway.
I am Woodbox over on the hamb and have been building a few cars covered on there for a few years now.
20m wide by 11m deep. Each bay will be 6.6m x 11m. Central bay will house the 4 post hoist. Left bay is wood shop and right bay is steel fab/shaping.
Central bay also has floor to ceiling pallet racking both sides.
Each side bay will have a steel beam to support the roof and run a gantry car for lifting to save my back.
IMG20260224130529.jpgstay tuned .......
Uncle murph
Harford county
Looks like it’s going to be a great space.
Stuart in MN
Minneapolis
Welcome to the site. From what I've seen it seems like garages in your part of the world tend to be pretty small, so this one may make your neighbors envious. 🙂
Craig Balzer
Colorado Springs
OK?
I looked at every sketch (nicey done, by the way) and didn't see one barrel.
I saw a notation for storm water to go to tanks.
Does tank = barrel?
Will you have 1x tank (barrel) at each corner; therefore 4-Barrels?
If not, please explain Your "Four Barrel Barn"
W
Woodboxkiwi
OK?
Does tank = barrel?
My good lady loves barrels (the wooden kind) I build hotrods with 4 barrel carbs.
W
Woodboxkiwi
It has been a busy couple of days. My mate turned up with his excavator and truck to help me drill 20 holes and stand 20 poles. We braced them all in position and tidied up today
Tomorrow (Saturday)morning at 8 am the concrete truck arrives to place concrete around the bases of all the poles. Next week we will cut the footing around the perimeter of the shed and box up ready to pour the floor.IMG20260619143718.jpg
W
Woodboxkiwi
Big (not so big) day today! 8am the truck arrives with 4.2m³ of concrete for the pole holes.
Brian from Virgin concrete was great, putting the truck exactly where we needed it for each hole so we didn't have to barrow any more than necessary.
Morgan came to give me a helping hand with the heavy lifting and barrowing. We managed to only need the barrows for the 4 small holes right near the house side .
We drained the truck dry and topped up the center 4 holes that don't have any further footing to be dug around them.
Now we wait for it to set before removing the bracing, digging the boundary footing and screwing the boxing timber to the poles.
Not long now and we can pour the slab.
W
Woodboxkiwi
This afternoon I set about removing all the bracing, profiles, stakes and associated **** that we will no longer be needing. With the site nice and tidy and easy to navigate we can proceed tomorrow with digging the boundary footing and box up for the slab.IMG20260621162229.jpg
W
Woodboxkiwi
Another day on the pad is over. More moving aggregate and fines around today and driving the plate compactor to establish our concrete substrate.
It seems that no sooner do we get it looking smart, then we dig it up again!
This time is to insert another conduit for the hoist power supply.
Last thing before I stopped for the day I started to distribute the 300mm x 50 mm boards that we are using for concrete shuttering/boxing, ready to position and fasten tomorrow.
We are getting close now
W
Woodboxkiwi
Wayyy better to dig up for the hoist power now than later...nice progress!
That's what I thought.
We had a lot of rain overnight, the footings are all flooded, and it looks like we are in for more today, so maybe a physical health day today and back into the hard graft again tomorrow.
W
Woodboxkiwi
A busy week of boxing, leveling, straightening, compacting and hiding from the rain!IMG20260628120020.jpg
With all the final fines in position and compacted.
The last of the sunlight on one of the shortest winter days.
Another truck loaded with mesh and associated reinforcing materials arrived this afternoon, before the contractor turns up in the morning.
The last view of my work before the contractor does his magic and we pour concrete next week.
I can't wait to have a floor to work on and get off the mud!
W
Woodboxkiwi
Another couple of busy days with the team placing mesh and reinforcement steel onto the pad.IMG20260702165144.jpg
While the lads were doing that I made up some roller door recesses to reduce the chance of weather driving under the doors.
The portion of the steel that is over the top of the boxing will be removed after the concrete, they are simply there to locate.
The brackets for attaching the slab to the bottom plate are cast into the concrete and simply tack onto the boxing then bend over the bottom plate at a later time.IMG20260702165029.jpgIMG20260702165015.jpg
Today the engineer visited to tick a few boxes, tomorrow the council building inspector is here to tick a few more before we cover it all in concrete.
W
Woodboxkiwi
Monday was a bust, due to a foreboding forecast of heavy rain....... didn't amount to much after all, so we could have gotten the floor poured. Tuesday's forecast was for worse...... turned out to be more accurate, so no concrete the rest of this week while the contractor has some time out to go to a fishing competition.
W
Woodboxkiwi
7am the pump truck arrived and the crew were here to start pouring mud!IMG20260713081128.jpg
Now we're are in the middle bay and still pouring. The weather is cool and clear..... perfect!IMG20260713082731.jpg
School holidays gives us the opportunity to enlist junior operators too!
All that hard work is disappearing!
I added 8 plates 6" x 12" x 3/8" to be able to weld to later for fixing sheet metal and dents in panels.
Door recesses look good 👍.
W
Woodboxkiwi
The team are putting the polish on now. Looking sharp.
I realized today is exactly 6 months from the day we started excavator work on the site.
The finish is coming up great and the sun is shining making the concrete 24°C when the shaded ground is only 10-11°C.
I can't wait to get on the floor to paint later this week after the concrete cutter has been.
It will take a while to undo all the boxing around the perimeter of the slab, then I will probably get the storm water drains on the ground and glued together before we put some fill on the ground.
Very happy with todays progress.
