40x48 concrete quote: $22k
malazan
Zero knowledge of slabs and welcome insight into if this is standard/fair quote.
$22k total
40x48 slab
5.5 in
4K psi
12inch footer
#4 rebar
33 ton gravel
Moisture barrier
2 inch foam board
PCustoms
VT
Seems about right to me, if not on the low side. That's a lot of work and a lot of concrete.
Getting another quote?
Seems cheap.
Around here the concrete is over $200/cuyd, and the rough estimate is double the material price for the finishing.
That slab has over 32cuyds, not including footing and all the other work.
malazan
Ty for the great replies. Virginia Northern Neck. The guy came recommended from a close friend. Still wanted to double with y’all but seems like it’s a reasonable quote. Thank you all for the feedback!
PCustoms
VT
Ideally you should get 2 other quotes.
Who is doing the site work, and how will that gravel be compacted?
tarmy
Nor Cal
That is cheap up here. I would make sure of their work…go look at other slabs they have worked…
WisJim
Menomonie, WI
My 24 by 40 garage slab was just under $10k in early 2020 just before Covid, so this sounds good, Mine included 2" foam and site work on an easy site.
txvwnut
Bedford, Texas
Not necessarily the slab work but some of the prep work.
Around here most of the contractors won't touch it if they don't get to do it all. The main money is in the site work not the actual pour and finish work, plus they don't want to be held responsible for any issues that may arise due to poor site work.
NUTTSGT
Northern Central Ohio
Fortunately there are guys around here that will come and do a pour/finish for a Saturday cash side job.
If you know them and they know you, cash is the key. It may not work for everyone.
kj_mustang
Harrisonburg, VA
A little further east than I usually ventured but the water views are bigger in that part of the NN. Back to your situation, I was able to find a concrete finisher local to my area that did all of my concrete pours on my property. I had him do 4 separate jobs over about a 3-4 year period. I did all the base prep work and forms and estimated the number of yards of concrete. He would order the concrete from the plant so it would get his discount and I paid the delivery driver direct for the concrete. Crew did all the concrete finishing and slab cuts. I had good referrals on the crew and after the first job done I knew I would only use them again. All four jobs were 2 or more truck loads each and they considered that an easy day since they mostly did big commercial jobs finishing 75-100 yards a day. If you are confidant in your friends recommendation, I would ask the contractor for the latest jobs they did and do some follow up on those to be safe. I would ask him how much stone he uses for base since that area is mostly sandy loam.
