40x60 Garage
1636Patriot
Hello, First post here... I am going for it this spring! 40x60 metal garage...figuring a 12x12 on the gable end off center and 2 or 3 10x10 doors down the 60' side...Any layout ideas? I was thinking a 4post in the corner near the 12x12 for stacking some Summer cars for storage and the oppisite side of the 60 foot tool bench, tool box, lift for wrenching...Also thinking a used motor oil furnace for heat...Any input would be appreciated.
nadogail
Coronado, CA
Your location will be important in getting you the best answers.
Honolulu will take less heat than Bangor. Some localities will have restrictions on the fuel you can use to warm your shop.
Welcome to the Forum.
rockcrawler
Dallas, TX
Welcome!!
1. Use ArcSite, SketchUp or some graph paper, and draw everything to scale and then play with layouts to see what works best. Someone on here posted that they used graph paper and then made cut-outs of items like lifts, cars, benches, storage, etc to scale and then moved them around on the graph paper to see what worked best for him.
2. What will your wall height be?
3. A layout/drawing of your shop positioning/location to other buildings like your house and driveways/street will help as well.
4. Some will probably recommend going over 40’ to give you room to park vehicles one behind the other. Maybe 45’ as 40’ can make it a tight squeeze for larger vehicles. 2 full size trucks will be over 40‘.
5. I’d recommend 12’ wide doors as 10’ can be a tight squeeze for full size trucks.
6. Maybe a door on the back side so you can drive through one of the bays if needed. And for additional air flow on nice days.
7. Insulated doors and insulated walls.
8. Air conditioning
9. If you put any lift near a garage door, I’d recommend a jack shaft opener for that door to give you more ceiling clearance. They are nice and quiet too.
1636Patriot
Thank you for the response....14 foot walls And I'm in RI in the woods so another heat option is a wood stove or furnace
