40'X60' Stick built Now with Trusses.
I've been watching the board for a long time, and finally I have something worthwhile to post about. Its a first build for me and as expected a little more money than I wanted. I'm excited, nervous, and so grateful I'm able to do it.
Signed with the builder and pulling permits this week. Its the start of my new garage. Now I have to wait for the ground to unfreeze so it can get started.
I'll probably be adding more detail than needed in hopes to help other fellow people who have used this site as a resource on what has and can be done.
For starters:
40'X60' Stick built with a 10' lean-to on the back (60' side).
I went with the stick build because it will be easier to finish and insulate in the long run. It will be used primarily for personal automotive repair and car building.
The walls will be 2X6 studs built on one row of 8" block on top of a 42" footing. Two man doors with one 12'X'12' and one 16' X 8' overheard doors.
Concrete floor throughout as well as under the lean-to with saw cut joints.
Spread web trusses which were cheaper than attic trusses but should provide some extra space for small storage. It will be finished off with .046 vinyl siding, and asphalt shingle.
An overview of the plans are below.
View media item 48228
Builder is doing the just the building and concrete. Once he is done I'll take over on the electrical, insulation and finishing. Electrical will be done right away, but the insulation and walls as soon as my funds recover.
As far as funds go, because that is a big part what people like see and what to expect. The building without overhead doors will run between 52 and 54K. with the land grading we need to do. I hope to have the electrical and doors all ran for a total under 60K.
As soon as mother nature comes back to Michigan, I'll post pictures as it happens.
I'm willing to take any advice you are willing to offer, and give any that is in my power to give!
Edit:
All pictures can be seen here:
http://s309.photobucket.com/user/pyrowaves/library/Garage build
I will be adding some of the key points as it goes to the thread, but more can be found on that link.
For starters:
Edit:
