Short winter days are here again and have been wanting to put some work lights on the little Kubota since I got it however none have ever met my Dutch pricing requirements.
Princess Auto to the rescue... They recently had some nice compact utility lights for $15 each and I couldn't resist. Made a bracket from some 1-1/2 angle and mounted to the ROPS (yes I know it says don't drill or weld but I'm not too concerned about a couple #8 screws weakening it to the point of collapse).
Turns out the are bright - so bright I need to control them individually. Since they are for use in the dark, I wanted to be able to find the switch easily, didn't want a toggle sticking out to get damaged and wanted it waterproof and to look somewhat like it belonged. And the final condition, I hate repeating things so it should outlast me (doesn't seem like a tall order some days).
Well, I ordered up some backlit pushbutton waterproof switches on Amazon, some 12V relays with connectors and harnesses and scrounged up a fistful of diodes, resistors and heat shrink tube and got to work.
The end result was satisfying enough to share. Switches light up half brightness with the dash lamps, full brightness when on (hard to tell from the photo but bottom is on) and looks like it belongs. Just need a reason to drive around in the dark now.
