5/8"-11 threaded mount drill chuck
avantech
Hi Every one
I am working on table saw remodel, I added a horizatal drill by using old used table saw parts, now I need a 5/8"-11 threaded mount drill chuck, I can not find it on line , I am wonderling is there such drill chuck availalbe on the marked ?
Thanks
John
amason3
You'll have to get a drawbar to adapt the 5/8-11 threads to something like a morse taper and then get the correct chuck.
larry_g
oregon
Not finding any either, 5/8-16 is the standard. I would suggest that you turn the 5/8 thread off and rethread to 1/2 or 3/8" to put a standard thread on the spindle. It could also be turned to a standard JT taper. What speed range and shank size do you expect on this spindle?
lg
no neat sig line
A
avantech
Hi Larry-G
That is my thought too, I want to know what is more accurate 1/2"-20 thread or JT33
I found larger end is .624 for JT33, thanks
John
Squashfest81
As a Shopsmith guy, I would just grind a flat spot on the threads for the set screw and slide on a Shopsmith chuck. They slip on a 5/8 shaft and use a set screw.
And Shopsmiths make great horizontal borers!
larry_g
oregon
Hi Larry-G
John
Your problem is that the ROOT diameter of the thread is is ~.510" and the small end of a JT33 is 0.5605 so you cannot get a full taper on there. As for accuracy in your setup I would say that is up the the machinist that re cuts the end of your spindle.
lg
no neat sig line
A
avantech
currently i use hand drill as the power later I may install a larger drill motor
john
