5/8" and 16mm Deep 1/4" Drive Sockets
JDweld98
There are two empty spots in my socket trays and these two are the cause. I know I'll probably never even use such a large socket on a 1/4" ratchet but I still have the overwhelming need to have them anyway. I've been searching and can't find any. Does anybody know where I could buy some to complete my set? Thanks!
chevy302dz
NE
SK did make them before Ideal took over, maybe they still do or are available NOS.
drink
Confused State
Never heard of them getting that big in 1/4" drive other than what the Chevy guy just posted about SK.
Fedwrench
Valley of the sun
Only because this topic about people with OCD needing to fill a Hansen peg has come up several times before. Zoro carries the Westward brand part #10E874 gets you a 1/4 drive 16mm deep 6 point socket while part # 10E864 gets you a 1/4 drive deep 5/8 6 point socket. Bothe will set you back less than $5 plus shipping so don't expect more than a peg holder :lol:
Plenty of options for shallow but, deep is another story. :beer:
Hansen trays ****!!!!!!
kythri
Lebanon, OR
Heh, I'm curious what trays, too...
Zoro/Grainger have the 1/4" drive 5/8" in 6pt/12pt shallow and deep.
I never thought to look for a 16mm, since my 1/4" trays only go to 15mm.
stage20
pcola FL
A jig saw or a cut off wheel will modify the tray easily and you won't need to have those unicorn sockets. I cut all my 3/8 drive down to 7/8. Could have gone smaller but I stopped there cause the tray fit in the drawer at this length lol.
I do have a 3.8 6.3 6.5 and a 7.5 1/4 drive shallows they will never make a peg for haha.
ihateminimumwage
Are you sure you're not looking for 15mm instead of 16mm? Never seen any trays with 16mm.
Snap-On 5/8" Shallow TM20 $13.20
Blue Point 5/8" Shallow BLPS1458 $2.90
Blue Point 5/8" Deep BLPLS1458 $5.20
Snap-On 15mm Shallow TMM15 $15.10
Snap-On 15mm Deep STMM15 $22.15
Snap-On 16mm Shallow TMM16 $15.15
454ragtop
Carver, MA
You guys with OCD are looking at this the wrong way. Are you trying to organize YOUR tools, or are you trying to set up a display of someone elses? Do you not like to drive your car if you don't have people to sit in all the other seats? I love to buy tools, but buying tools just to sit on the peg of a socket holder is crazy. If you don't want to shorten your trays, maybe black out the sizes of the ones you won't use or shorten the studs a little and use the open spot to store duplicates or whatever.
Jim
stage20
pcola FL
Worried about the finish of the inside of a socket you'll never use? Yes.....we are addicted to tools lol
gungatim
west mich
I have an S-K 5/8" deep in 1/4" drive I picked up at a flea market. my tray doesn't go that high so I have the opposite problem. they are out there, just keep looking...I've never seen any other brand in that size though.
BK13
PDX, OR
I THINK Wright makes a 5/8". Now you just need to worry if it has detects or not. LOL
Rogue1987
Missouri
I think I've got both Blue Point and S-K in those sizes.
90zcar
I bought a blue point 5/8 for mine. I use it aswell from time to time
pepgj
Jim
Maybe there's another way to be OCD here.
Let's say I owned a 1970 SS454 Chevelle convertible (which, actually, is one of the few non-Camarostangs I've had). A person could take the factory assembly manual, make a list of every connector in the car, and buy a full set of wrenches/sockets for just those sizes. Add some pliers, a couple of hammers, 2-3 screwdrivers.
Then you put the whole deal into a small hand carry box, and call it done.
Seriously, I wonder how many sockets and wrenches bought in sets ever get used by people at home.
casestudies
Happened to be looking this up the other night while trying to decide between two SK 1/4" dr sets (48pc vs. 60pc). One set had 16mm and 5/8", but the cheaper one didn't but had a small thumb ratchet. HJE has standard sockets:
5/8" 6pt std SK40920
16mm 6pt std SK40715
Looks like they don't carry deep sockets in these sizes though. Now I remember that the other two sockets I had in my list were standard and deep 4.5mm.
90zcar
I happened to have a 15mm snap on only because I bought the set and it included it. I never bothered to buy a 15mm deep nor do I intend to
The two 5/8 blue point sockets were maybe 2 bux each
The Hansen trays also go ridiculously small in the 3/8 size. I cut those pegs off and on occasion I lay a different socket or two in there or an estranged crack pipe...lol
pepgj
^^^huh?
It was a long-winded way to say that if you're a specialist hobbyist (let's say 1960's Chevrolets), you really don't need large sets of much of anything. Just buy what you need and it'll all fit in a small container.
454ragtop
Carver, MA
Consider shortening the pegs just below where the size is marked instead of cutting off completely. Or consider running the whole tray thru the bandsaw, shortening it up, did that with some Kobalt trays.
toolaholic
PA
I have a proto 5/8 and 15mm in 1/4 drive. I used the 15mm twice to remove nut that holds metal Heater hose line in front of gm 3.1v6. Low torque big nut. Used the 15 on the lower intake manifold job and on the timing cover job. Both times for metal line that runs in front of motor.
bob15
Northeasten, CT
Not sure with 16mm sockets, but the 5/8 is good for Chevy/Delco starter solenoids. The 1/4" ratchet is smaller and will fit into tighter places and I find it harder to over-tighten that solenoid nut with a 1/4 drive ratchet over a 3/8 ratchet.
jim faston
The guy at Hansen who designed those trays is probably having a good laugh.
ss454
mi
I will have to look, but I am pretty sure I have usa craftsman in 5/8 and 15 deep and shallow in 1/4 drive. yes, it is the perfect tool for the starter wires.
stage20
pcola FL
they are near identical. only four thousandths seperate the two the 16mm being the larger.
radrush
Atlanta, GA
No way in those sizes on the Craftsman. Craftsman never offered those sizes in 1/4" drive.
I'm nearly 100% USA Craftsman but those two sizes in 1/4 drive I got from SK.
And SK (currently) only offers those sizes (16mm and 5/8") in 6 point shallow.
unashamedlaborer
Guadalajara, MX
Got a picture? Otherwise, I remain skeptical.
The guy at Westling is laughing just as well.
You got me by a few minutes...
I can get you one tomorrow. Blue point 5/8" deep 1/4" drive. Snap on shallow 5/8" 1/4" drive. Matco 15mm deep 1/4" drive. Idk what the shallow 15mm is. I'll have to look. Use the deep all the time though.
unashamedlaborer
Guadalajara, MX
Ok sorry. All hail the SK Brand. Never seen any support for service or warranty. But I'm sure they are there like ninjas in the night. Really who cares...... What is going to give first your 1/4" ratchet or a 5/8" 1/4 drive socket. I don't get what all this ******* match is about.
wolf_from_wv
WV
Autozone even sells the 15mm shallow and deep...
I just use metal rails... Added the 15/32 and 17/32 socket on the rail...
90zcar
Found a 1/4 drive 15 deep at autozone. 4 biz. Taiwan made!!
kythri
Lebanon, OR
So far Westward is the only brand I've seen that has these sizes in deep and shallow, 6pt and 12pt.
Some brands have one or two of those, but not all of them.
90zcar
They also offered a 15shallow
