Between 265 & 485 SQ/FT 5 acres and a farmhouse
N
NBraun
Well so far it's been an eventful June. No progress on the porch because our septic drain field decided to finally call it quits. We want to see how much that will run us before spending any more money on other projects. I've spent the last two weeks trying to get a few quotes from contractors and that's been a process on its own. To the point, I'm grateful I'm at least capable of doing most of the things around the house.
In the interest of not spending money, we decided to finally clean up some dead fall and brush in part of our shelter belt. We had a derecho go through a few years ago and it toppled some trees, and the drought the last few years has started to hurt some of the older trees. I've been trying to figure out what I want to do with it. The west side is older and very overgrown and that's where we are losing most of the trees. The North side was planted in the 80's I believe, so it's still fairly healthy. We discovered most of the brush is Buckthorn, an invasive that is able to choke out a lot of native trees. It's also somewhat of a pain to kill. So that's something we can work on once it's a little later in the summer. I'm hoping if we get rid of that a lot of the native trees will be able to start to fill in the empty space.
Not the best picture, but the only before I could find.
It's been a pretty dry spring here and our water bill shows it. We have a windmill and well on the property that I've always wanted to see if I could get going. It hasn't been used since the 70's so we really weren't sure what to expect from the well. I figured now's a good time to see what we can do with it. I quickly realized the sucker rod was completely froze up and I would have to pull the pump to figure anything out. I asked one of the plumbers that came out that also works on wells if he could pull it and work on it for me. He said it'd have to be pulled with a well truck, and by the time I paid him it wouldn't be worth it since we're already on rural water. So that just made me more determined to do it myself. I didn't have much to lose since it currently doesn't work.
I built a 4 pronged brace that sits in the windmill. I attached a ****** block on the bottom of that. I then backed my truck up to the windmill and used a 12v winch in the receiver to actually pull the pipe. It actually worked really well. The hardest part was separating the pipe sections as I pulled them, and I chose to do it on the hottest day we've had. The well ended up being 180' deep, and I hit water around 80'. However my dreams of this being a low buck project quickly faded once I started researching new pumps. My options are basically replace it with the same pump jack system, which I'm still waiting to hear back for quotes on the sucker rod, pipe, and pump; or use a jet pump, which some quick napkin math would be $2,000 - $2,500 for that. So the jury's still out on what I want to do.
This was the setup. I'll grab a photo of the brace once I pull it down from the windmill. It was 100 degrees out and I wasn't thinking about photos.
Bert_
NW Iowa
I have a 25' dug well on my yard. I use it if I need to water things. Mine also has a windmill but I just drop a submersible pump down it with a garden hose.
I scrounged the pump (free) quite a few years ago and it's a 120v pump. That's not real common but it's nice that I can run it from an extension cord.
Have to remember to shut it off after a couple hours or it will pump dry.
N
NBraun
That's not a bad idea, for what I want to use it for. The hard part i think would be finding a submersible pump that would fit in a 2" casing.
loganb
Omaha, NE
I love the DJ20! Might have to steal that idea for dust collection to use on mine...though so far I'm just using the built in chip chute and the broom or shop vac to clean up!
Bert_
NW Iowa
2" casing? I don't think I've ever seen anything like that. Definitely rules out any kind of submersible pump.
N
NBraun
The shavings being shot back up in my face was enough for me to decide it was worth it to figure something out lol.
With the reorganization of the basement, I've been needing to find a solution for the tool batteries. I've been mulling it over for a while and decided last night to finally just start building something. The back of the miter station is 13.5" deep. The shelf is for storing the circular saws, they're oddly shaped and I've had a hard time finding a specific spot for them. I want a spot for every battery I own, without wasting a bunch of space, so I came up with the sliding boards. I should be able to fit 3 on one side for all my batteries, )each holds 8 batteries) and have room on the right for tools. It just a mock up right now, I'm still figuring out how I want to do everything!
N
NBraun
Don’t forget a timer for the chargers. You don’t want another problem cooking the batteries and causing a fire.
Oh for sure. I am overly cautious about that. Right now the chargers are plugged into a plug that gets turned off with the lights, so they're never on while I'm not actively in the basement.
"Finished" iteration of the drill station. As I'll do the finishing details later. It wasn't till after I finished that I realized that I could have gotten away with 2 vertical dividers, but it will work the way I did it.
I also finally decided on what I want to do with the top of the miter station. I was trying to decide it I wanted to do a laminate top, or just use shellac. I prefer the look of shellac, so that was the winner.
I also finished a window sash that I've been trying to rebuild for a few years now. I've tried this a handful of times already and this is the first one where it clicked and I'm happy with it. I used dominos instead of mortise and tenons, because I'm bad at cutting small mortises and it was a little quicker.
The miter station coming in handy.
I still need to cut the angle on the bottom, but I'm pretty happy with it for the first finished product. Working with Sapele is very nice too!
And the last project for the weekend. My wife and I have been planting some trees and perennials around the house this year, so we've slowly been cutting beds in as we get rain.
N
NBraun
Short little update..
Been focusing on the porch and house projects,
We tore down the old enclosed porch minus the roof. We dug and poured a footer for masonry steps and the porch, then framed out a floor with 2x10's. Filled them with R30 Rockwool bats and 1" EPS foam underneath the joists. Also got started on the front door. The goal was to get the porch dried in before harvest, which we have, and the door+Sidelights done before it gets too cold to finish them outside. We'll see about that one.
20250718_164051.jpg20250829_122208.jpg20250906_091828.jpg20250906_123020.jpg20250907_111412.jpg20250808_194958.jpg
xtremek
St. Johns, Mi
Looks like it's going to be a sharp replacement for the porch. What are you doing to keep the vermin from coming into the bottom of the insulation. I'm using left over tin siding under the insulated shed floor. I'm told it won't be enough.
N
NBraun
I'm still trying to figure that one out. The EPS is all sealed with spray foam and foil tape. I'm sure they'll be able to chew threw that, but I've read they don't like the rockwool. I've read some people will put plywood or OSB on the bottom too. At that point I'm not sure what else a guy could do.
