jollygreengiant
Good to see you posting again!
12'x16'I would love to have that timber framed gazebo for a patio
It really is a dream come true! We both had hopes to live on an acreage sometime down the line, we just didn't think it would happen so quick. In our area, there aren't many options for places like ours. So when the opportunity to buy came up, we decided we didn't need to use the wedding fund for the wedding after all!My wife would actually be head over heels with your place, the little farmhouse, chickens and goats…
.me still surprised you still working out of your basement.
I can only imagine you building an Amish quality timber frame garage!
Very nice house. I recently purchased a walker turner radial drill like that. completely tore down and undergoing refurbishment.It really is a dream come true!
Thanks!Very nice house. I recently purchased a walker turner radial drill like that. completely tore down and undergoing refurbishment.
BTW, my best friend lives outside Langford SD.
Merry Christmas sir! Love the Radial drillpress too! I've always had a similar love for them...don't really need it but just super cool and if I ever get a big enough shop would love to have one!
Awesome work on the door and the drill press!Thanks! Knowing that I will eventually have a larger shop to store some tools made my decision a little easier. It is a large footprint for what it's used for!
Some more progress though.
In preparation for building my miter station, I needed to find a better home for my small metal lathe. I used a slab from the maple that I milled. Cut the slab down so I can mill it with my 6" jointer and then glued it back together. I know that soft maple may not be the best material for something like this, but it was free, and to be honest, probably stiff enough for the lathe that's bolted to it. I finished it with shellac, because it's easy.
More progress on the drill as well. It's been slow just because of the slow nature of the products, but progress is progress. I've been using citri-strip to remove the paint. It was painted again at somepoint, and that paint is coming off very easy, but whatever they used from the factory is ON there. I figured if it's lasted this long, and still on there after using a stripper, it's probably fine to paint over. After that it gets dipped in Evapo-rust, cleaned and then primed. The base is what is taking most of the time.
More progress on the door as well. Cut and assembled the muntins, and have got the lower panel glued in. At this point, I need to figure out what we are going to do for the lites. Since it'll be a door for the goats, I'm weary of using non safety glass, though safety glass will be expensive. I also am not sure I want to use something like plexiglass, because it'll look bad with the rest of the door.
No, but now that you mention it, that would have been a very good idea.Just curious, are you something under your base cabinets to keep moisture wicking up from the basement floor?
Good work on your projects.
Thanks!Just read through this thread, beautiful house and acreage. I like how that miter station came out, between that and your outfeed table looks like plenty of flat work space and storage too, nice layout!
Your porch looks very - very familiar.Thanks!
A bit more progress on the drill press. The motor did not get repainted, but I cleaned it up and it got two new bearings in it. The wires however were in rough shape. When I took it apart I didn't look to close at the wiring. I figured it's a 3 phase motor, so as long as I hook up the same 3 open wire I should be good. Well my VFD came in, and when I went to bench test it, I realized it was wired up for 440v, and about half of the wires didn't have any ID. So I spent a night Ohming everything out to figure out which wires were which. I also talked to a local motor shop who recommended I just run heatshrink over the existing wires instead of having them relead it. I did the best I could, without taking the rotor out of the housing. Anyways, I got the VFD wired up and was able to bench test the motor, and luckily everything works.
And Excuse the mess...
And now a different project...our poor porch.
I had full intentions of pulling this apart and fixing it last year, but wanted to hold off until work lightened up. Unfortunately that never really happened, and then I went to northern MN instead of working on house projects.
The first year we were here, I dug new footings for the two posts that were sagging the most. I also sistered the joists, put a new rim(?) joist, and installed a new storm door. Some of the window sash's were in poor shape, but they still held the weather out and without us knowing what we wanted to do, would work for the time being. Well, we lost a couple windows and the others continued to get worse. I decided today was the day to tear into it.
How most of the sash's looked.
This was freshly painted in 2020. We Scraped it fully down to bare wood, used a high quality oil based primer. We then had a Deracho go through and sandblast the whole south side of the house. We got all the old sash's pulled.
We pulled the siding, and tried to do it nicely, so it can be reused, but a lot of was just too far gone and rotted. The story was the same for the bead board on the inside.
Here's a picture of the dog. You can also see the interesting joist connection.
Here you can see how rotten the floor board were. Everything on the bottom was pretty well gone.
Here you can see my bandaid fix with some of the flooring gone.
And the stopping point..
This is where we're at. I need to figure out where to go from here. The end goal is to enclose it again, and try and make it comfortable for most of the year. Even if we have to add heat or A/C. We both loved the room during the winter, and so the whole upper half being windows was great. The bad part of that, was it was only usable for like 2 weeks of the year. I'm debating just redoing the framing for the floor. It was not built strong enough and the floorboards had some spring to them. I'd almost feel better if we tore it out and built it the correct way. After that is windows. The easy button would be just be buying some windows, but I'm throwing around the idea of building them. Either casements or single hung.
I love what you ended up doing with the porch. It looks really good!Your porch looks very - very familiar.
We had similar problems (see signature "the porch").
You can get a lot of opinions - but only you know what you need.
I'll be honest, we could have tried to harder to save it, but I just didn't want to deal with scraping the lead paint if we were able to reuse it.Boiled linseed oil helps a lot on weathered, dry wood. I've done some basement windows sills that way. There was maybe a few flakes of paint remaining on them when I bought the place. I soaked them down with BLO, then primer and paint and they are holding up well almost 6 years later.
Seems like the porch floors were always built too light. Mine has 2x6's spanning 13 feet. I think the simplest solution for me is to break the current 2 spans into 3 spans, longest being about 9 feet.
The TBI 350 leaves a bit to be desiredI love the 88-98 chevys
I still like them. Driven a lot of tbi 350's. I have a TBI 4.3 in my k1500 and I still like it.The TBI 350 leaves a bit to be desired![]()
