5 point security Torx?
jpilgrim
QflXjHlRNNgQU1rh.medium
Never seen this before...
Anyone have a source for drivers/tool to remove?
Edited: Yes, I say "Torx" loosely, given the profile of the lobes.
MrMark
Southern Cal.
That's not torx. Torx and Torx Plus each have 6 lobes. Torx Plus security is an exception and it has 5 lobes but it also has a center pin.
No idea what that is.
kornbln
Wonder if the secure torx plus would work on it. By the way what is this from?
TAftw
Check Wiha, they seem to have a lot of those odd bits.
billymade
New Mexico
You might try to find the apple "service source" manual for the new Mac Book Air, typically.... they will specify what the screwdrivers/fasteners are. There are also a number of sites that specialize in new apple product "take apart guides". These guys take pride in being some of the first to do so, they typically also tell you what tools you'll need! Good luck! :)
http://www.ifixit.com/Teardown/MacBook-Air-Model-A1370-Teardown/3745/1
From the article; it would indicate it is a "Torx Plus 5-Point Torx Screwdriver".
Sorry if I am sounded redundant; looks like you may have already looked at this article! Maybe call or email ifixit and see what tool they used, where they sourced it from! :)
thisflatearth
Wayne, NJ
http://www.amazon.com/Silverhill-Point-Tamper-Proof-Piece/dp/B002P4YCGM
http://www.toolwarehaus.com/STAR%20TORX.asp
http://www.amazon.com/Anytime-5-POINT-TAMPER-SECURITY-SOCKET/dp/B0026WMIV4
Just googled 5 point bit and go to images, looks more gooder than a flat blade
I am a sucker for buying more/the right tool for the job.
They all seem to have the security bit hole, but for the size of the screw I wouldn't worry about it. Usually when I have a security torx I knock the pin out and use my regular torx. I do have a small set of security torx bits though.
cortez
Chicago
This set looks like one of the bits could do the job.
I use them often for restaurant toilet security screws. Most stuff inside a restroom use security screws of some sort.
KenS
I wouldn't be surprised if the MacBook screw was smaller than a T-8 Torx Security bit.
dankicksass
New Jersey
Other Macbooks use regular T5, T6 and T8 torx. Given there's nothing serviceable inside the new Air, I don't really see the point of opening it but the 33 and 100 piece common security bit kits from Amazon, HF and everywhere else don't have 5-point torx in them.
mrshaun
Killeen - Fort Hood
humVee injector pump has a tp25 ttx25tpe to remove one part and they are apparently hard to find around here if I am out of stock on them. I had a t27 that was used on a generator the other day on a motor home.
we should see more of these as time goes by. mustang gt transmission a john deere application and porsche cayenne turbo. thats about it so far.
billymade
New Mexico
A little googling reveals; according to PCWorld:
If the new MacBook Air is anything like the iPad, as Apple claims, then it should be almost as difficult to tinker with. Sure enough, iFixit's MacBook Air teardown reveals an almost-impenetrable fortress, packed with proprietary parts to discourage modification. Here's what iFixit learned from disregarding Apple's roadblocks and peeking inside the new MacBook Air:
Stay Out, Warns Apple
Even the screws that hold the MacBook Air together are proprietary. To get through the 5-point Security Torx screws, iFixit had to file down a couple of flathead screwdrivers. Normal 6-point Torx screws hold down the inside of the little laptop.
http://www.pcworld.com/article/208555/macbook_air_teardown_5_findings.html
They look like torx plus to me!
http://www.google.com/search?client=safari&rls=en&q=torx+plus+5+point&ie=UTF-8&oe=UTF-8
BINGO! I'm sure this is probably the same as the Mac Book Pro! It looks very close!
Torx Plus 5-Point T6
http://www.ifixit.com/Tools/Torx-Plus-5-Point-T6--IP6-MacBook-Pro-Battery-Removal-Tool/IF145-070
