dwp99
Hello, I have a couple questions about the running of a dedicated circuit for a 200 amp welder.
The welder has a 3 prong plug 2 hot legs and a ground. The 3rd prong is grounded to the chassis of the welder. I want to run 6-2 with a ground from the breaker box to the outlet which is approximately 40 feet away as the romex is routed. I plan to run the romex overhead in the attic and then into 3/4" conduit as it comes out of the ceiling to the outlet.
1. Would this be the correct way to do this?
2. Is 6-2 heavy enough to carry the load of 50 amps?
Thanks
Thanks
