50 by 60 design and layout... 48 by 68 build
stamanti
Massachusetts
Couple more photos from inside. Diamond grill on the gable window to complement a similar window on the house.
stamanti
Massachusetts
That looks really nice! Itching to get in there?
Dying to.
The plan is to erect the interior wall 7.5' off the back gable end starting monday while the roofers are working. This wall will create the bathroom, mechanical room, and storage area.
After that I need to get the in-wall electrical, in wall plumbing, and in wall speaker wiring done in preparation for insulation.
After insulation, then the ceiling needs to go up, then lighting ... and then I can start to move in.
rs1968ss
Kearney, MO
Your reply sounds just like me describing my build. I need to do this, then this, then this and this. Then I will be ready. Oh, I forgot, I need to do this also. :lol:
Hephaestus29
Indianapolis
If you have the yard space, I would
build it wider not deeper. Like maybe
30-40 ft deep and 75-80 feet wide.
1 car deep 1 car in 1 bay
stamanti
Massachusetts
Did you ever find an easier light calc software to use? I need to do this for my build asap. Any online versions you know of?
Anything better than this that is free and on line?
http://www.e-conolight.com/resource_center/resources/lighting-layout-tool
I never found something easier. I just taught myself how to use dialux evo, which is free to download. It took many hours to get a passable model, and then figuring out where to find IES files of light fixtures I would actually purchase. Hopefully that work will pay off once the lights are installed.
swharris
So. Cal.
Trying to do the same. Can you point me in the right direction? What units did you end up going with? There is a high-bay light thread here on GJ, but it's a bit old and not a huge help. My contractor is getting antsy.
Are you direct wiring or putting plugs in above each light location? I'm getting asked that question and a thousand others. Lol.
stamanti
Massachusetts
I'm doing a 5x5 grid of 2 foot led high bay lights I got from Home Depot.
They are lithonia ModelIBH 11L MV.
I will direct wire them, but will probably do 3 separate circuits. One for the center run on motion sensors, then a left bank and a right bank.
stamanti
Massachusetts
Roofers started and completed their work today.
The garage is pretty close to weather tight.
stamanti
Massachusetts
Siding started to go up today.
Morton's crew cab f350 doesnt look too big in the garage.
stamanti
Massachusetts
The garage also fits my truck with loaded trailer after a track day.
This is geometrically evident from the plans, but being able to pull the whole rig into the garage was a welcome realization with torrential rains forcasted for tonight and tomorrow. Now i can unload at my leisure tomorrow.
stamanti
Massachusetts
Interior wall framing went up today, and siding continued.
OH_Varmntr
Beautiful building you have there. Can't wait to see the finished product!
stamanti
Massachusetts
Yesterday work continued on the bathroom walls, storage area walls and storage loft.
I'm thinking of changing the destratification fan from a single 10 foot fan to two 6 foot fans. The 6 foot fans could then be mounted above the lights between the trusses up high. This would eliminate any light strobing issues with the fan, and would keep my clearance uniformly to 12 feet from floor throughout the garage. The 10 foot diameter fan was going to be mounted at 10 feet a.f.f.
davetulk
Mid Florida
Killer build!!!! Do you ever plan on finishing the ceiling? If you are that may affect your fans. You could finish around them, make a box, but would make a sort of wind silo affect. Also moisture above ceiling.
If you are never finishing the ceiling then I say good plan.
stamanti
Massachusetts
I'm going to keep the trusses exposed. The only ceiling finishing will be applied direct to the underside of the roof.
davetulk
Mid Florida
Sounds like a great plan to me. Got any spec on the fans you are looking at? I got 21' to the center collar ties of my shop on a traditional framed hip roof. Looking for a fan to put up there.
stamanti
Massachusetts
Just starting to look now. I was looking at Big *** Fans for the 10 footer, but I just could not swallow 5k for a fan.
stamanti
Massachusetts
Lightning protection was finished today.
Siding continued.
Garage door install Friday.
My dad is advising that I have a floor coating applied before I move in. I'm getting pricing for a grind and then epoxy sealer install, and a gray epoxy option.
Not sure what I want to do.
In my head the garage has a polished concrete floor, but I believe that would not be a good finish for a garage that is worked in.
stamanti
Massachusetts
Garage door is on.
stamanti
Massachusetts
The half round siding is proving to be very labor intensive, but I am happy with the look.
stamanti
Massachusetts
Looks like morton is complete with the exterior.
Now on to furring out the walls for insulation, electrical in wall, and plumbing in wall.
Boosted1
Georgetown, KY
I would agree w your Dad on doing floor before moving in.
There are several options that are very durable.
I did a Ucoat DIY install on my floor over 10 years ago and it still looks ok.
And I know there are more durable options.
Polished concrete also looks really good.
ard
How long has that slab been down??? Beware you need to let it fully cure before coating.
I like a grind/polish/densifier. A working floor that still cleans up well. AND (as I understand it) can be redone in the future.
Head over to the "flooring" subforum- good advice there....
stamanti
Massachusetts
Slab was poured on April 4th.
I only have one quote for the floor treatment at the moment, but I have two more coming.
From the one quote the polished floor is 25% more money than the epoxy. For that difference, I think it is worth it.
stamanti
Massachusetts
Started plumbing in wall.
Picked up some garage equipment.
stamanti
Massachusetts
Over the weekend I got the speaker wires through the walls in preparation for insulation.
Azek flat boards were installed in preparation for exterior lights, and hose bibs.
Electrical in wall to start tomorrow.
