What brand? Any pics?
I got mine from Costco too, four in a 24'x 28'. They are well worth the $30 each when I bought them. NOW as stated , $25.00 !!
I am also very pleased with my Costco LED shop lights. I bought one to change out my single bulb garage light; it works very well to light up the whole area and comes on to full brightness instantly. I went back a couple weeks later and bought 12 more for my shop that I am putting up.
I replaced 3 4' T12 dual-bulb fixtures with 3 LED fixtures from Costco. They're brighter and light in the cold. I'm considering picking up another three to put in the back of the garage for more intermittent use.
http://www.costco.com/4’-LED-Shop-Light-with-Pull-Chain,-2-pack.product.100223617.html
They're available in the store singly for $25 each now.
doesn't look like they can be hardwired. I have 16' ceilings so they need to be wired to the switch.
I can find the lights I have on the costco website, looks like it is in store only. The lights I have do not have a pull string for on/off.
All I did was replace the switched single bulb socket in my garage with a standard 120V wall plug and then plugged the light cord into the switched wall plug. For my shop I plan to chop the plug off and hardwire the lights since it will be a new construction setting as opposed to adding to old construction.
Here is a picture of the light that is hung in my garage and also a picture of the lights in boxes I have waiting for my shop.
Sent from my SCH-I545 using Tapatalk
we just switched our house round bulb lights (from CFL and incandescent) to LED. First thing we noticed is that they were "brighter". Ended up switching most of them down one size (from 50 watt LED to 40 watt LED) to get back to our comfort level.looks very bright!
With 16' ceilings, OP should be using 4ft fixtures that put out 7,000 to 10,000 Lumens.
Considering the grey walls, better stick with 10,000+.
Wow, almost 9000 sq ft! That's some serious square footage you got there. There aren't many here who have a full compliment of LED fixtures like you do. From a few quick mock ups, you have 65fc avg in the storage area and 70fc avg in the shop areas. Lumen output of the fixtures is right where it should be for your ceiling height. Well done.
I appreciate the concern and the work will be done safely however where I live I dont need permits or inspections for anything except septic (from the county). I know there will be plenty of people who will go off on me and stress the importance of adhering to code but the way I see it is if it is done safely then it will be ok.FYI it's not code compliant to use the lights as hard wired by cutting off their plug. Do whatever you want it's just a heads up
Mine was a new build:
80 x 72 5 rows of 5 fixtures in the storage area. The Car Shop and Machine Shop areas are 40 x 40 and each have 9 fixtures each. The height of the 3 areas is 16 clear.
http://www.barronltg.com/resources/0...s/tled528a.pdf
I have the Model # TLED528A-200
And from an old post and thread...
In the office I also used LED. In the bath I reclaimed an old warehouse light. The Utility rooms have T-5 Fluorescents since they are only used when I am in there.
We are going through the motions to upgrade our business with LEDs. We have 225 fixtures in the main plant and about 156 in the office. Bids are all over the map from $15k to $197k. We had our power company rep in to baseline everything for us and give us a little better direction on the best method. Replace the whole fixture or replace ballasts and bulbs or just bulbs...hard to know who to believe when you don't have the time to investigate yourself.
Has anyone put overhead LED lights in a garage yet? A friend of mine just built a new shop for his company and instead of fluorescents they used 4' LED lights through out.
CobraJake - This linked PDF has 6 pages with different lamps on each page maintaining your existing layout: (wall reflectance reduced from standard 50% to 30% due to color)
Pg1 = F32T8 Fluorescent (output similar to what you have now)
Pg2 = LED bypass lamps
Pg3 = Qty. 24 F54T5 Fluorescent Strip Lights
Pg4 = Qty. 24 ZL1N 5000 Lumen fixtures
Pg5 = Qty. 20 ZL1N 7000 Lumen fixtures (linked - this is my preference)
Pg6 = Qty. 24 ZL1N 7000 Lumen fixtures
The grey walls are costing you 8 to 10 fc overall.
An alternate to the 4ft LED bypass lamps would be 8ft LED bypass lamps as mentioned in this thread (linked).
I'm not sure which fixture you are referring to.free shipping this month. Those would prob be the easiest? but would i need as many fixtures?
If you're satisfied with the amount of light you have in there now, then retrofitting with LED bypass bulbs is a viable option. If you want more light then the ZL linked above or similar 7000+ lumen output fixture will work better for you.the ZL1N 7000.
Although I was told today to just buy the bulbs and retro fit them to my existing fixtures?
