YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 503
Can anyone please recommend me a whitworth 6 point socket set that I can get off Amazon plz. I don't have whitworth sockets at the moment, so looking to get a variety of sizes.
Brooklyn hipster locally sourced organic artisan pickle brewery?Are you working on British motorcycles or turbine engines? Trying to remember where else I’ve heard of whitworth sizing on fasteners.
Italian and British auto restoration shop foreman checking in. Even here Whitworth is extremely limited use.
Most of my techs use the Toolzone brand Whitworth stuff from Amazon. They are fine. Nothing special, not terrible.
I have a collection of vintage Craftsman Whitworth wrenches, I usually reach for the cheap toolzone stuff first.
What are you working on that you would need this esoteric nonsense?
I would love to find a vintage King **** set of Whitworth combination wrenches
Most folks in the U.S. forget that from about 1958 most British vehicles use “Unified” rather than BSF / BSW, so for most of the “classics” ( everything from Mini’s to E Types) they are not needed.I would love to find a vintage King **** set of Whitworth combination wrenches
Gedore never offered 6 point in Whitworth, as far as I can recall. Snap on did, but only in 1/4” drive.Makes a difference if I recommend Gedore or vintage Craftsman or Snap On
Oh yes - it’s the design date that’s critical, and there’s a load of stuff that’s a mixture! Land Rovers are notorious, and with a bit of accessorising you can find yourself needing Metric too!They were still used in stuff that already used them, though, so things like land-rover transmissions had them until the series 3 (and actually, I think there are some in that box, b ecause it wasn't all new). Quite a lot of 60s cars had UNF or UNC fasteners holding most of it together, but still had engines, diffs, and transmissions that hadn't made the switch. Don't need whit stuff for routine tasks, but major overhaul, you did. I recall working on something that had a bracket attached to the engine and transmission. One was a UNF bolt, the other BSF.
the tension knob on Brooks saddles is still a whitworth head, unless it's been changed since the Italians bought them.
How long is a piece of string? Which model an early 1.4 base model or a later twin cam? clean driver or sitter?How much does classic fiat 124 goes for? Not spyder but the basic sedan.
Me too. Early one. Early 1.4 base model aka the real deal that the soviets copied. clean driver.How long is a piece of string? Which model an early 1.4 base model or a later twin cam? clean driver or sitter?
Most importantly, are you trying to get rid of one? I am actively looking for a good restorable early 124 sedan
Well, as I said above, the options for 6 point Whitworth are pretty limited, for the reasons given. 12 point no problem.I'm asking to complete my 6 point socket collection. Got to collect all sizes like Pokemon cards. So the Tool Zone ones on Amazon are 12 point. Any good 6 points?
Koken good but pricey, anything less expensive for something I hope to never use?
Defiantly times were a whitworth size would have helped me for rusty metric fasteners that shrunk, and the next closest size down in terms of across the flats would have been a whitworth.
So how come a set of regular 6 point metric sockets costs 100 bucks and the z series costs 163 bucks from koken? Same drive same socket sizes?Well, as I said above, the options for 6 point Whitworth are pretty limited, for the reasons given. 12 point no problem.
In fact, the only other manufacturer I can think of that offer 6 point are Deltec, who manufacture impact sockets. Lovely tools, very good quality, and sockets up to 1 1/2” square drive, but they won’t be any less expensive than KoKen.
KoKen, in the scheme of things, I wouldn’t really consider pricey. Sure, I know it depends a bit on where you are (I know they are more expensive in the U.S) and exactly which tools you are looking at (Z series are more costly) but the Whitworth sockets are part of their regular range and not generally costly.
Ultimately, it depends on your perspective. You’re never going to get good tools for comparable prices to really cheap ones.
If you know what you are doing, you can get very good tools for mid prices - that’s where KoKen sit. Or you can get mid grade tools at low prices, but both good and cheap are seldom found on the same tool. That applies to pretty much any tool.
I imagine KoKen would say that the Z Series are made to tighter tolerances. Maybe a different steel to cope with the slightly reduced wall thickness? Probably all cold forged to get the accuracy. All of which has a cost.So how come a set of regular 6 point metric sockets costs 100 bucks and the z series costs 163 bucks from koken? Same drive same socket sizes?
Whitworth were the very first standardised screw threads (1841). They are relatively coarse threads, as they were designed for use in iron.Cool topic. Never heard of Whitworth sockets but I never really worked on much British stuff. Interesting to read about. Regarding the fasteners, the normal standard or metric size sockets aren't close enough to fit, even if the numbers don't match since W isn't based on head size?
Did BSF fasteners have the same across the flats (AF) sizes as Whitworth? Meaning you can use whitworth spanners on a BSF fastener? If not, what is the name of the tooling used on BSF fasteners? I only know of SAE, metric, and whitworth. I think in the early 1900s in the USA there were some different standards like USS or something like that, but they had the same AF dimension as other wrenches. So basically called something different but AF dimension could be found in other tooling. But not sure about this?Whitworth were the very first standardised screw threads (1841). They are relatively coarse threads, as they were designed for use in iron.
The size of the bolt heads are standardised for each thread size. So, whereas with a Unified thread, you have to know that you need a wrench of 7/16“ across flats to fit a bolt of 1/4”, with a Whitworth thread a 1/4” bolt uses a wrench marked 1/4”!
In later years, Whitworth threads were called “BSW” for British Standard Whitworth. “BSF” threads are British Standard Fine, and were optimised for use with steel.
A metric socket can be up to one mm oversize. An SAE socket up to 1/16” oversize. So, while sometimes you get lucky and they are close, it’s not onerous to use the correct size.
On a typical vehicle you might need up to 7 or 8 SAE wrenches. Potentially 10 to cover the same size range metric, but you only need 5 in Whitworth!
Oh thats right! Cold forging! Even usa made wright sockets are hot forged. I think that was one of my deciding factors when shopping for a set of sockets.I imagine KoKen would say that the Z Series are made to tighter tolerances. Maybe a different steel to cope with the slightly reduced wall thickness? Probably all cold forged to get the accuracy. All of which has a cost.
Yes and No!Did BSF fasteners have the same across the flats (AF) sizes as Whitworth? Meaning you can use whitworth spanners on a BSF fastener? If not, what is the name of the tooling used on BSF fasteners? I only know of SAE, metric, and whitworth. I think in the early 1900s in the USA there were some different standards like USS or something like that, but they had the same AF dimension as other wrenches. So basically called something different but AF dimension could be found in other tooling. But not sure about this?
Thanks for all the help and information!
Yes, BA sizes are found a lot in the U.K. and on British manufactured goods. Although in theory replaced by smaller ISO metric sizes, they are still used.Thanks for the info. I guess the only somewhat other useful standard is BA sizes. With 0BA and 1BA the only likely ones I'd ever need.
I have encountered that only rarely.Another thing to mention to really muddle things up is recently a couple of hex headed Whitworth / BSF bolts I have purchased have actually had metric hex heads, presumably as Whitworth sized hex stock is harder to come by.
BA threads are actually metric, a 0 BA being 6mm, and each subsequent diameter being 90% of the previous. This is a very logical way to proceed, as the steps between sizes get smaller as the diameter reduces. More logical than ISO metric.
Frequently used in various places on British car fuel systems, . . think SU carbs.Trying to remember where else I’ve heard of whitworth sizing on fasteners.
I think they were generally 12 point because most Whitworth bolts are of reasonable quality and you can use 6 point or 12 point without drama. Older wrenches were often 6 point.I'm guessing any Whitworth sockets I've ever seen were always 12 point because they will drive both a hex or a square head bolt. Square head were common on screws with a Whitworth thread. Old british machines often had both square and hex Whitworth screws on the same machine.
From memory the metric head Whitworth thread bolts were probably Britpart supplied for Land Rover series.I have encountered that only rarely.
Most bolt heads are forged, rather than being turned from stock, so they would have to be pretty crappy bolts!
There was a Swedish standard that used Whitworth thread with metric bolt heads. You find it on a lot of Swedish machine tools.
What size bolts?
One thing to be aware of is the change that took place during the war. When it was decided to use the smaller “BSF” head size for Whitworth bolts there was a problem in the smaller sizes because no 1/8 BSF existed. They got around this by using 4 BA heads for 1/8 bolts.
Similarly, the 3/16 BSF (1/8 BSW) was used only rarely, so they specified a 2 BA.
So, if you encounter any 1/8 or 3/16 post war bolt they will need 4BA and 2BA wrenches.
This is something I seldom see written down, but it’s the way it is! So when you see a “set” of wrenches including 3/16 BS, understand that this size will only be found pre war!
That’s interesting.From memory the metric head Whitworth thread bolts were probably Britpart supplied for Land Rover series.
I buy all the BSF bolts I need now for Blackstone Engines from Balls Fasteners, in cap head instead of hex head.
I’m pretty certain the XPAG was a pre war design. I think it came about because Lord Nuffield banned MG from having dedicated parts made, and insisted they use standard Morris items.If you want to get really infuriated, Postwar MG XPAG motors used what is known as "Med Metric" where they are metric threads with Whitworth sized heads.
I have also rebuilt a 30's Daimler inline 6 that had standard UNF and USC 60 degree threads with Whitworth sized heads.
