I love this thread! It’s been absolutely informative. Ddang has pretty much hit the ball out of the park with awesome information. Two ground rods should meet your inspectors needs. I do not install these, but I generally find them about 8-10 feet apart.
In some larger installs I’ve seen up to 10 ground rods. Sometimes if the building has copper plumbing, you can usually latch onto it.
One of my shops is in almost the same situation as yours. The buildings are fed through 2 inch conduit and are 8 feet apart. I just used a pneumatic chisel to drive into the ground. I am just using bare ground wire to rods. I was a little bit **** and I put up two more lightning rods attached to each peak wired to the ground rods. I had one building lost to lightning 20 years ago. I’m so ****, I have a 21 foot stainless steel chimney that is sent right into a ground rods
