I missed out on this thread up until now because I've been on my phone app a lot and mostly read "participated" threads. It appears you've done some great work on this thing so far, I'll check it out better when on my computer this week. Keep it up!
too much pitting and set screw marks.Go back to first post, edit it using advanced editor and you can change title.I should add that it is not actually from the 60s, but rather 47. The owner said 60s but that was for a different model. I wish I could change the thread title.
since I won't be putting it in the garage I will trade this and use the Dayton it came with.
from there use a screwdriver then prybar to knock it off. The windings are perfect, as is the wiring and bearings surprisingly. Armature is rusted but noy pitted. Mineral spirits to clean windings? Or WD-40?
looks like peanut butter!
dark machinery gray
forgive the mess, my lathe bench always is covered in filings, sawdust and random sandpaper scraps.
I wasn't trying to remove all pits so I started at 180 grit, then skipping some steps went up to 4000. I tried it wet but it didn't leave a shiny finish? I didn't have tailstock support so I always pushed the sandpaper towards the chuck. It hopped out once before I remembered.
Now I will take them to the car wash this week and blast them all with hot soapy water to get all of the crud and grease off. Before priming I'll do a final degreasing with acetone or brake cleaner.
luckily the primer cured before morning, no damage done.
Now is a good time to talk about paint choices. I used valspar cobalt cannon, the same as my 100 model drill press and table saw, and wards jointer. It is my favorite shade of blue-er dark machinery gray. The very bottom is the as found gray on the base, with a band of valspar on top.
according to other photos the gray is a bit darker blue, http://joeswoodshop.yolasite.com/resources/10ER Jog Saw Picture1.jpg it's all I could find and had extra on hand.
I broke the edges with a mill ******* file then a sharpening file and round file on the edges. I started out with a file on the sides but quickly went to a dremel with 400 grit drums. I quickly realized that was ideal and did the sides with that. I then hit the whole thing with a 220grit sanding sponge and put it on! I am super pleased with this, it's the tiny details that make a resto special.
Does anybody know how to adjust for wear in a casting? I do not have the ability to bore and sleeve, I am looking for something more simple. I really appreciate any input whatsoever, even if you have never done it before anything to get me thinking is good! I am thinking of a Teflon tape of the quill lock threads to give enough resistance to apply slight pressure on the quill via the brass wedges and keep it tight without vibrating unlocked.
Thanks for any input!
Thanks, good luck on the Mark V! I know somebody who just redid one. They are certainly way more practical, and support and finding parts is easy through the actual company. There is also an easy fix for the quills on the Mark Vs, there are lock tabs that can be bent in, making the races effectively smaller. If you have any questions, don't hesitate to ask! There are other things I did that I don't think I took pictures of.I like your detailed write-up of this resto - I'm going to follow many of your steps when I start work on my Mark V.
Sorry I can't help with your loose quill - I have the same problem but I haven't taken it apart yet to figure out how to fix it. Good luck figuring it out!
Thanks Nine! I have definitely put more time into the shopsmith than anything else, but I am loving it's looks so far.Love your shop and the SS is coming along great! What about putting a small tack weld around one lip of the loose sleeve, then hand filing or dremel sanding it down to tolerances? You don't need a machine shop but you'd have to be real careful. Looking at what you've done so far, I think you're capable of whatever needs to be done.
Great work man!
Will do, I will be testing everything before, don't want to end up stuck! I have this metal impregnated gel epoxy that is designed for cast iron. I used it on a 4" drain pipe that cracked and it dried rock hard. I might try that instead.If you try the JB Weld, or any epoxy method, be sure to WAX that quill and it will slide in/out better and also clean up well. Also, be sure to wipe the race area real good with acetone or similar so that the JB Weld adheres to it better. That's an old car audio installer trick.
Thank you! I figured it's time for a quick update. I ordered a bunch of rod, bearings and drive screws and am just waiting. I got the 1" bar last weekendI have to say you do some awesome stuff, with a nice eye for detail.
Many thanks for sharing sir.
This brings back memories. This was my late grandfathers 10er. It had been sitting in my parents basement for 40+ years. I dug it out and it is now my go to drill press. I added a variable frequency drive to mine to make it more useful.
View media item 93202
