7/16 OSB over kraft faced insulation?
speedwaytaco160
Clarksville TN
Hello everyone.
I currently have kraft faced insulation in my ceiling of my detached garage. I am wanting to install 7/16 OSB over that to help with keeping it from falling and humidity control. Ive read that OSB is considered a Class 1 barrier. Would you recommend cutting the kraft paper and installing an vapor barrier OR just installing the OSB over the kraft paper.
I plan on staggering the sheet when possible. 2x6 running 24" on center.
Thanks, Ray
Kaizen
New England
Face of insulation is a vapor barrier. I also do thick mil plastic to reduce air movement.
Will a 6 foot span sag at all with that ply? Wonder if adding some strapping you can go to thinner and reduce weight
NUTTSGT
Northern Central Ohio
I'd put the OSB right over the Kraft paper insulation. However, knowing what I know now, I'd use ribbed metal siding instead of the OSB.
kbs2244
My OSB went right over the paper face.
But I have 2 inches of vented air space between the top of the insulation and the underside if the roof sheathing.
The idea is that the space will vent any moisture that get through the paper.
speedwaytaco160
Clarksville TN
I have about 1 1/2 inches on the top side of my insulation. I used to have sky lights in my garage but since then had a new metal roof installed. My humidity level is normally in the upper 40's-50's .Today it was 76 but its been raining. I plan on filling in the spots (old skylights) with a baffle and some insulation, and installing OSB. I have some condensation spots on my kraft faced paper due to the breaks in insulation.
speedwaytaco160
Clarksville TN
Thanks Everyone. I shall give this project a try I may have to take some leave from work. Plan on renting a scissor lift and a drywall lift to get this knocked out. Thanks everyone
