7/8" sq drive for pipe plug?
slackdaddy1
Southern MD
I have an 80gal air tank with 2 large (2") bungs on the side.
each has a pipe plug with a female 7/8" - 15/16" square recess.
Tried a 3/4 drive breaker bar, it was about to spin in the recess.
do they make a 7/8" sq drive wrench for this ??
Nick
fordnut85
Yes they make pipe plug sockets for them, I have a snap on set I use a lot for drain and fill plugs in the automotive world. They seem to fit ALOT better than a ratchet or an extension.
Sent from my Pixel using Tapatalk
ChrisLS8
I have a set for my Nissan, was a small company that isn't around now..Nissport I think
Steve_P
Try Williams or proto for a socket. Not sure if they make one that big though...
KnurledNut
n/a
Bend a L-shaped shim and put it in with the 3/4 ratchet.
Or get a countersunk plug wrench.
slackdaddy1
Southern MD
But,
"I Got's To Know"
Free 80 gal Horz tank,
when I pulled the bottom plug I was greated with 175psi of about a gallon of clear water and a quart of white oil.
Really want to pull the 2" plugs and take a looksy.
Grabbing some 1" sq bar stock, welding it to a 4' pipe, and grind it to 7/8"
I'll let you know
That is a hint to leave it alone.
PoorOwner
CA
my calculation shows you should be able to fit a penny on each side of the square drive
junkyard trick?
