Strouty
Let these problems motivate, not frustrate. Getting mad at the mess is fine, but the best way to get even is to clean it up or finish a project.
Some more thoughts on this.I can understand the struggle........
Some additional insight: Perhaps you need to examine what you define as perfect? Is it someone else's instagram, pinterest, facebook or even garagejournal post? Maybe you need to define what is your "perfect", but factoring in your situation, finances, time and resources.
I've come to the conclusion for my shop, that my "perfect" or "good enough" is different than the glamour shots posted in much of social media. In fact, I often remind myself of this when scrolling thru Pinterest, etc. I've tried to define my "perfect" as "functional". Hence, if it works, good enough. I don't want to spend precious time chasing after a "perfect" solution when it really doesn't matter. Case in point, I have a tool topper/storage for my tool box for my Dewalt cordless tools. It started off as some scrap OSB I had sitting around. After cutting, forming and screwing it together, it has continued to work well. I was going to remake it out of "nice" plywood, but so far, it works well as is that I hate to spent time remaking it. I have other things to do.... I'll see if I can find a pic.
If you can define what you really want, then it is easier to gauge if current choices support that. And also to look past the "paralysis by analysis" to get to where you really want to be. It's also a moving target, so realistic short term goals help to get to long term bigger goals. Progress also breeds progress. I think you were getting some good progress on the mower, so work to continue that.
As we have reminded you when you were agonizing over a small detail on the little forklift (crankshaft issue, etc) work to push past it so you can get to the point where it is functional. Once the item is functional, it helps to overcome little issues that do not need to be show stoppers. Isn't it great to have a functioning smaller forklift??? Who cares on the paint, as long as it will move stuff when you need it.
For the record, I have recently gone through a pretty heavy shop clean up. Got it to the point where I could pressure wash the floor!
Wow......how did you get pictures of my shop from a few years ago.And here's some photos of the current state of the mess. i'll just wait for comments.![]()
Thanks guys. I want to purge, but its really hard to keep on top of it when it's going on. I am seeing things i can divest also. Hard to sell much around here though. It's the clientele in the area.
I am thinking i will try to finish the mower, clean up the yard then pull at least large items out so i can get some more room. There's a bit of pallet racking in the front of the car that could get some stuff before i am out of altitude. I did just get rid of an old microwave that had been on the floor of the shop for over 10 years. One lucky guy at work got it for his new apartment. Baby steps.
YEP, that's a mess alright, best you fix it. Lol.
Thanks, i wish i was closer too. I'll never get south i think. Unless i start a business and work from wherever.Working on the truck, i tried to mount and balance my own tires, the tire machine was not working and the balancer doesn't have a cone big enough for the dually rims. 100% fail. 52 dollars later i have 2 balanced tires, but one of my rims is bent, that's just super. And there's basically nobody anywhere that has that rim. super.
Too bad you aren't closer to me. I have at least 10 1 ton dually rims. I would give you one.
On the projects and organization woes... I am in the same boat most of the time with excessive perfectionism getting in the way of getting stuff done. That's why I like you and Strouty's threads, kindred spirits and all that. I now have an entirely new problem trying to handle Dad's 60+ year collection.
I have 2 lifetime collections to unwind.
I threw the new shroud on tonight, and the cooling is MUCH MUCH better. Before without shroud i could mow for maybe 5-10 mins and hit 220F on temp gauge. WITH shroud i was hitting 205-210F steady state mowing high grass even after an hour. The cooling is way better. I do feel that there is still recirculation going on through gaps in the lower shroud that i did not account for. With the bent lower rad tank, i believe i will need some custom shrouding. I think i felt this as good cool airflow on the top of the rad reaching behind my seat, near the top, and getting much warmer as i moved lower on rad. I'm going to pull it back off tomorrow and tweak some more. I think i can get it pretty much good enough to mow for the season, and maybe i look at the aluminum rad and electric fan later after things get cold. We'll see. Stay tuned for tomorrow's update.
I am helping my mom get rid of all of dad's stuff. A little at a time.Care to elaborate on this statement?
It's going to depend on how much better i can get it. I'm not comfortable running it at the current temp of 205-210. It wasn't that hot last night and i want to get it to where i can run at higher ambients.That's excellent news! Having said that, I don't think I would mess with an electric fan if the manual fan is doing the job.
I am much more aware of my mortality these days. I'm 54 next month. I won't last forever.
And my kids are not following in my footsteps. I have no-one to hand anything down to.
So i need to document everything i have so that my family can divest without being taken to the cleaners.
I have a lot of very very expensive tools. Marketed right, they could pay for a lot of months of income that
will no longer be there.
You're lucky. I have basically no-one. My brother could maybe help with cars, but he's not into what i am at all, and he isn't into tools as hard as i am either, so he probably wouldn't know a lot of what i have and what it's worth to the right people. I don't trust anybody at work to not take advantage of them. For instance, the hydraulic crimper i just picked up. There's one on ebay right now for $8700 with 10 dies. Mine's not worth that much, but an easy 3-4K. Wife wouldn't even know what it is other than a hose-thingy. Or the American Pacemaker. 4-5K maybe all painted up? It won't be the 450 i paid. She'd get taken to the cleaners.I understand where you're coming from. I'm 55, our time on this planet is at least halfway done, and my daughter is not likely to follow in my footsteps.
In case I die tomorrow, my wife has a several page document that lists the collectible cars, where they're located, what they're worth, and who can help her to sell them.
I'm fortunate that I have a very close friend that I trust implicitly that's a car guy; in case I depart this world without any notice, he could help. I don't have a good plan for the tools, but I need to work on that.
While a bit depressing, legacy planning might be just the thing to help give you the focus to clean, organize and tabulate your valuable items. Take a picture of each item, list what it is and the approximate value along with what you paid for it. Then list where you put it, might be helpful for yourself as well. The other consideration is insurance.... having a list of what you have and pics to prove it would be very helpful if there was ever a fire or storm. Fire is more likely based on welding, flammables and density.
This could get super deep and complicated quickly, but you might start with the larger items first.... indoor forklift, outdoor forklift, lathe, pallet racking, 4-post car lift, 2-post car lift first. Later you could get into the specialty tools.
I follow a lot of auctions, and many of the auctioneers specialize in tools and vehicles, and they do a decent job of describing and pictures. But some of the specialty tools definitely get short changed. It might be good to at least list an auction house that could be leveraged and be knowledgeable.
The worst thing that could happen is that nobody realizes that there is valuable tools/items in the shop, and instead sees a giant pile of **** and calls the garbage truck service to load it up and clear it out. This could also be a good incentive to clean and organize a bit.
Could you recruit a family member to help take pictures, and write down the preliminary information while you're doing this?
I'm glad you're getting closer on the mower, don't let perfect get in the way of cutting some grass and enjoying driving it!
Bimmer - I must admit to doing you a major disservice. I have read a lot of your previous posts to this thread and the Salvage Garage and thought "what an arrogant p....erson". What makes him think he knows so much better? Now you have explained your own journey I understand completely the message you are trying to get across. Basically don't get bogged down in details and just get things good enough to do the job. Sadly I don't think either of them have the sort of mentaity to work that way but your message is spot on nonetheless. Please accept my apologies for not understanding.Bulletpruf and Kent have made some great points. I use a spreadsheet to track my garage purchases. The key is to not make it so burdensome that you don't want to use it. It could be as simple as Date of purchase, Price, Brand, Type of machinery and a brief description. As you work on something, value add, or goes from a chunk or scrap iron to a working machine, you could add an "estimated worth" cell.
That said, I think it is good to be realistic on the values of equipment and the status of it. A working machine under power is going to fetch a bit more than a "project". I'll be overly blunt and pick on the lathe. You paid $450. If it is in any way disassembled, it will probably go for scrap price or a little more. If it is assembled and working, it could be worth $1250 to $2500 as a working Lathe. Certainly value-add could happen if that particular machine has a couple of bidders. While paint and polish could make it more attractive, then you're marketing to a different type of buyer. Not sure what the actual market is for a fully restored piece of equipment. (I would also suggest being careful to set yourself up for false expectations on your restoration of the machine...) As a case in point, I was surprised at how long it took me to refurbish the head of my Bridgeport. I also have a horizontal bandsaw that I was intending to restore. It is currently in pieces and about half of them are painted and the other half needs some work and to be painted. (I have determined that I appreciate those who restore machinery, but it is not a favorite process of mine....)
I also think it would be interesting to note on the spreadsheet the current status -- i.e. project, working, or work necessary. Then a driving goal should be to get your equipment working and connected to power. This should help drive your decision making on next steps and also allow you to note parts and pieces necessary to reach a milestone on a project.
Here's an example:
Mower. $1500. Repaired Wheels/Tires, Electrical system, Mower deck and the radiator. Still needs some work to radiator. Items to purchase --Belts, bearings, etc.
Value: Priceless when it is cutting the grass!!! (maybe $2k when complete).
Personally, I would recommend thinking about not buying any other "projects" and perhaps trimming the current projects so that you can focus on the ones that are top of list.
My observation is that top of list would be your mower, your vehicle and after that the forklift. You've made great progress on the mower. I can see you are so close!!!!
I think your next "win" will be either the forklift or the car. Both would be a huge win. (cleaning the area that Kent suggested would really increase your productivity in the shop and also give a sense of accomplishment. Eat the elephant one bite at a time)
Personally, I believe when a person has a clear goal in mind (and a time deadline) it forces you to make decisions and push past issues that mentally hold a person up (i.e. the perfect storage solution, etc).
Regardless, thanks for reading our posts this week. The intent was to be helpful, but it's not always easy for a person to listen to. Some of my insight comes from reflection on my own journey and learning experiences. Here's to a productive and fulfilling weekend!!![]()
Seagoon - no worries. I was concerned that my posts could be perceived as arrogant.... I tend to try to be precise and concise, so it can be a bit blunt.Bimmer - I must admit to doing you a major disservice. I have read a lot of your previous posts to this thread and the Salvage Garage and thought "what an arrogant p....erson". What makes him think he knows so much better? Now you have explained your own journey I understand completely the message you are trying to get across. Basically don't get bogged down in details and just get things good enough to do the job. Sadly I don't think either of them have the sort of mentaity to work that way but your message is spot on nonetheless. Please accept my apologies for not understanding.
Yes, that's a tall ask for a non-family, based on the amount of time it would take. I am a bit overwhelmed with what my dad squirreled away, and i'm even a car guy who knows a lot about what he did. It is neither quick nor easy to unwind a collection.That's a good point about auctions. I need to do a bit of research on how that works, but it might make more sense than relying on my buddy, who lives out of state and would need to take a significant amount of time off work.
Man i wish you weren't so far away. Maybe one of these days, after i get my channel started, we can collaborate on someWe should do a YouTube video on getting one of the Fairlanes back on the road. Message if you want to discuss further.
Bimmer. As an also-blunt person, i don't take your posts as arrogant. Only as helpful. I appreciate your time taken to post suggestions. Also it's taken as intended. I wouldn't post my dirty laundry here if i wasn't looking for help. All comments are carefully considered and absorbed.Seagoon - no worries. I was concerned that my posts could be perceived as arrogant.... I tend to try to be precise and concise, so it can be a bit blunt.
Both this thread and the Salvage garage are interesting, and I want the best for them.
Maybe some of my comments will help to modify mindset or behavior so they they can actually achieve their goals.
Or at a minimum provide some interesting or reflective reading.... Not intended to piss anyone off, but I'm sure that happens too... Oops.
Onward and upward guys! Have a good weekend.
