Above 1200 Sq/FT 86's 20HP shop
Strouty
Southern Maine
I have an entire drawer full of wire stickers with numbers on them. I use them whenever possible, they all came from a $5 auction pallet, best $5 I spent in a long time. I would guess that it will be a "lifetime" supply for me.
86turbodsl
Sweet. Wish I found some in an auction. I'm alright without labels for now. Simple system really.
Sent from my LG-TP450 using Tapatalk
86turbodsl
Blar! Doing some research this morning i think i need to add more 24V outputs. I'm up to 7 on a 8 output module. I think i need at least 2 more since i can't directly control the VFD via modbus with the CPU in the PLC. The D2-240 doesn't speak modbus. So i was planning to output discrete DC to turn it on and off and a variable voltage to control speed. That could be avoided by moving to the D2-250 cpu i already have, but i didn't want to burn that high $$$ cpu on just the boiler. I was hoping to save it for a future beer brew stand since the 250 is the lowest CPU that has PID controls.
I think i make life too complicated.
86turbodsl
Lol.
I got tired of school after my bachelors.
I found a 16 point output module in the pile last night. I love automation direct stuff. I pulled the old module, swapped wires over to the new module and plugged it in. Everything worked just like before, but now i have 8 more outputs. Done in 15 minutes. Gotta love it.
Shop is staying at about 50F without running, so i think i'm over the hump. Going to focus on cleanup and getting the burner upgrade done as well as working on my sons truck.
86turbodsl
Yeah it's fun. Especially when it works!
The 16pt module I swapped in wasn't working until I realized I needed to supply power to it. The old one didn't need it.
Added some terminal blocks and wrote code to control the preheat tank fill. It works well. Hope to start cleaning up by tomorrow.
Feet are frozen. Going inside.
86turbodsl
I finally got the temp sensing working last night. Correctly wired a rtd transmitter and signal into the plc. It moves when I touch it. Now I need to calibrate them and write code to make it usable.
A buddy at work gave me a decade box that will get me calibrated.
Getting closer. Once it get the first one worked out, I'll roll out the rest and we will have some true automation. Once it get it started I can walk away a bit. Or even do an overnight burn.
86turbodsl
Mom gave me one of dad's compressors. Good tide me over until I get the quincies going.7d3f3d1d1e6d2c645039ad80192e6a7d.jpg
86turbodsl
Tucked into it's new spot. Need to power and plumb it yet.25676dfea175a6fb315747d3a2ed2cb9.jpg
Strouty
Southern Maine
I played that game, when I got my first Quincy, I sold the IR that I had to help nudge me into fixing the Quincy, a few years later......
It feels like winter again, I am saying that after Wednesday, there is no more cold allowed.
OldSoldier
DFW
The compressor looks good there. Since it is in the lean-to I imagine it will be pretty quiet inside when you are using it. Do you think you'll have any issues with moisture on humid days in the summer?
86turbodsl
I would expect i have to drain the compressor regularly, especially in the summer. I did look quite a bit about compressors exposed to cold temps and the only thing i found was that they can be harder to start in the cold. THe usual fix is to go synthetic. As this compressor was quite loud when i've used in the past, i didn't really want it in the shop. If it works well enough to get the quincy(s) done and installed/painted, i think they will be quieter. This one has an aluminum pump, so it's probably not rated for the kind of duty i expect to put it through. If i remember right it took quite a long while to pump up too, so i think the pump isn't that large. It doesn't even have a mag starter on it, so i think it might be on the edge of the capacity of the pressure switch. nameplate says 22Amps. i have to look up that and see what the real capacity is. Coleman suffered the compressor overstatement issue too.
86turbodsl
Yep, looked up the rule of thumb for single phase motors is 7amps per hp, and this one at 22amps puts it a hair over 3hp actual. Coleman calls it a 6.5hp compressor. Sure. Cfm is around 10. It'll work for now.
86turbodsl
I wired the compressor tonight. It's loud, but only outside. Can't really hear it inside. Love having air again. Now I have to get my lines setup.
86turbodsl
I am pumped. I taught my boy how to mig weld tonight. And he liked it. :) Happy dance! He's going to be working with me as i teach him all the processes. He may even turn it into a career. We shall see! Woot!
1Garageman
Columbus, Ohio
That is awesome teaching your kids how to do things. I have greatly saved a lot of money with what my father taught me, and I enjoy doing it. He will definitely appreciate it later on in life!
Perrorojo
Northern IN
That's awesome. My son has no interest but my daughter wants to learn so she can do metal sculptures.
86turbodsl
Thanks guys. I hope so. I really wanted to pass along some of my knowledge to my kids. So far, they've been mostly interested in their devices. My boy seems like he's getting hungry for an income though, so i'm seeing positive changes.
Bert_
NW Iowa
5 amps per HP is pretty close for 240V single phase motors. Some of the larger 5hp+ motors can be closer to 4 amps per HP, especially newer premium efficiency motors.
Strouty
Southern Maine
It is tough these days, most school systems don’t have a handle on reality and teach kids to become good little factory workers. My nephew is 12 and he has some interest in mechanical things, but not as much as my brother and I did at his age. I think the hardest part is that the things the kids use these days are not easily user serviceable, so it makes it tough to find a common ground project, one that you know about and they are interested in, that can be fixed or upgraded.
86turbodsl
I think it helps I'm into older stuff that is repairable. All of our vehicles are older except the wife's lease car. But I hear you.
Perrorojo
Northern IN
We use Watts at work so you can figure Amps based on Voltage. Approximately 746 watts per HP. I work mostly with inverters and everybody wants to run an air conditioner of a 1200wh battery bank and a 160w solar panel.
86turbodsl
If you go by wattage and claimed amps, the equation says 7hp. I don't for a second believe a 7hp motor runs off the standard pressure switch. No mag starter remember? And that's at 100pct efficiency. It's a Coleman, more likely a cheap motor. I believe 60 to 70pct efficient, no more. It might hit 4hp. Not 5 for sure.
86turbodsl
Tried to go to town and the truck was starving for fuel. It's been like that on the rear for a while, now it was on the front. Got fairly Draconian with it yesterday.
Found lots of little plastic bits in the tanks from the grenaded pickups. Common high mile Ford problem. I'm sure the selector valve is full.
Question is whether I put a 38 gallon rear in, or just fix the 19.
ef93b7a1c5a197a7b8fae2673e5771f3.jpge01c8bd97c6ca18c9172652e4fdaccb2.jpg824d06792b67d9e7320c4f37697f59b6.jpg511025e366804f38f3e5eca6fbfddaea.jpg
matt_i
This is twin 18s or 19s? I think I would keep the dual tanks. There's something nice about having that backup fuel pump on board :).
I have a GM custom deluxe of similar configuration, replaced all of the pumps and selector valve in '04. But somehow last fall I blew out an exterior flex hose on one of the pumps, was pumping a gallon per mile on the road....gotta tear it apart just like that to get it going again.
Good tough trucks, just a little slower and thirstier than a turbodiesel. But....the monthly payment on these old trucks is right on!! :beer:
86turbodsl
It's got twin 19s. I thought about the 38g rear tank and keep the front tank. Up the total. I get about 14mpg. Even diesel. Crew dually 4.10s. big slow truck. I took the valve off, it was stuck and unrepairable. Need a new one. There's only one pump after the tanks.
86turbodsl
I decided to save the cash and stick with the 19 gallon rear tank. I think i'm going to just put a hose on the pipe down to the bottom so i don't have to worry about this problem again. Now to clean the tanks out and get them back installed. I have to cut off the crappy homemade gooseneck hitch first and get my B&W installed.
