A-Circle carb tool
Tynee
In the Heart of the Bluegrass
Afternoon, gentlemen. Any recommendations for a quality A-circle carb adjustment tool? I bought a cheap one on Amazon because that's all I could find, but the pin broke out of it. Any help appreciated. Pic for reference of what I'm calling an A-Circle tool:
T
Tynee
That means you didn't find the answer you wanted. I know what "Thanks gentlemen" means.
Didn't mean to be glib. Just frustrated that there seems to only be one manufacturer of this tool, and that's the one that I bought that broke the first time I tried to use it.
I'll probably see if I can cut a slot in the head of the screws and try to turn it with a flat tip screwdriver.
I do legitimately appreciate the responses, though.
Wamsutta
Amarillo, Texas
Can I make a suggestion?
If you ever decide to get a different blower, the STIHLs are the easiest in the world to adjust. The mixture adjustment screws are right out in the open and easy to get to. The tool is a simple 4mm hex driver which is available on eBay. The quality of the tool is exceptional.
swsman
Earthbound
You can take a dremel to it with a small cut off wheel, make a slit so you can use flathead screwdriver to adjust the idle.
I have done it in the past.
T
Tynee
Agree. I'll likely go shop Echo and Stihl. This one is a bit of a special case. My son completed a program a couple years ago where he volunteered to mow 50 lawns for disabled, elderly, veterans, etc. When he finished his 50 lawns, the founder of the program drove up from his home in Alabama and rewarded my son with a lawnmower, a trimmer, and blower. The equipment was all donated to the program by Lowe's, so it was all bargain barrell stuff. The trimmer and mower didn't make it a full mowing season. The blower is all that's left. I'd like to keep it useable for him as along as I can without dumping a ton of money into a disposable piece of equipment.
More on the program for those interested:
T
Tynee
