I'm part way through the installation process for my new Max Jax lift. All assembly is done and I've determined my post spacing. Next up is drilling the post mounting anchor holes. In doing all this I've read through the manual several times and have two questions.
1) In the manual it states that if you remove the posts and store them the next time you set up you need to re-bleed the cylinders. It would seem that with the self closing hydraulic fittings no air can get into the system when removing and reassembling. If you take down your Max Jax and store it are you bleeding the lines when reinstalling?
2) The manual says you should install the supplied C-clip lock rings on the swivel arm pivot posts after mounting the swivel arms. Again this seems like an unnecessary step. Do any of you actually use these C-clips and then have to pull them off to remove the swivel arms? Getting at the C-clips to pull them off with a pliers could be a bit of a hassle. Plus my experience with this type of lock ring is that repeated installation and removal tends to weaken and enlarge them so they don't hold very well.........at least on smaller rings.
Neither of these two steps are mentioned or shown in the sales literature I read or the online videos but both add noticeably to the "ease" of installation/removal that is touted in the advertising. I'm wondering if they are there for the benefit of the legal department.
Thanks,
BH Davis
Thanks,
BH Davis
