Just letting you know that I'm still following along 1/2 cup, just don't have much to add other than it appears all is going well. I hope you are enjoying "some" of your down time.
Dan, it is always great to hear from you and thank you for dropping by
Things are progressing well in the
West Wing. not a lot that is picture worthy as most of the electrical work you don't see save for a new socket outlet, switch or light fitting at the end of the day.
Thus far:
. Electrical material take off and procurement.
Completed.
. Disconnect and remove all the old cabling to 15 lights, switches, fans and fixtures.
Completed
. Rewire all of the above.
Completed
. Install all of the new light fittings, fans and switches.
Completed.
. Added two extra lights and two mains powered smoke detectors.
Completed.
. Fabricate, install and paint a plaster reveal to cover the old bathroom fan, heat lamp and light fixture cutout that will allow the installation of a new fan, light unit.
Completed.
. Stove cabling rough in.
Should finish today.
. Split air conditioner sub circuit rough in
Should be complete today.
. Rewire 14 socket outlets.
Completed.
. Rewire and reconfigure ceiling fan cabling in the back porch. Clean and reinstall.
Completed
. Rewire and reconfigure the central gas heating system controls and duct damper motor.
Completed.
. Rewire and reconfigure roof space lighting and socket outlet.
Completed.
. Removal of all the redundant split conduit and old cable from the roof space.
Completed.
. Remove and replace two sheet of roofing to gain access to the redundant cabling and inaccessible connections.
Completed.
. Mow the
lawns, yet again.
To do on the electrical upgrade:
. Remove, clean and replace dishwasher.
. Remove, clean and replace wall oven.
. Install kitchen exhaust, wiring and switching completed.
. Install two LED down lights over cook top, wiring and switching completed.
. Start on the replacement of the last power circuit which involves replacement of those old wall boxes, chasing the walls, rewire then replastering, repaint and fitting off of seven socket outlets. That will complete the power circuits and I should give it a fair crack this weekend.
. Perform the mandatory testing at completion.
. Reconnect each final sub circuit and test operation.
. Issue a Non Prescribed Certificate of Electrical Safety to Energy Safe for the works completed.
Then to close out will be the following:
1. Main switch board and metering replacement.
2. Mains and Main earth.
3. Powerco disconnect and reconnect.
4. Mandatory Electrical inspection for what is called Prescribed Electrical work.
I will be getting a hand with this from a mate of mine as it is very much a two man job.
As you can see there is a lot of work involved just in the electricals and being the age that it is, of solid brick construction inside and out, 10 ft ceilings with limited under floor space access certainly presents it challenges, I full well knew what we were in for when we purchase the home but a job worth doing is one that is worth doing right in my book and none more so than the
West Wing Electrical Upgrade.
I am keeping tabs on my hours and materials just out of interest sake as I would hate to think how much it would have cost had I not been able to do the work myself.
Thank you one and all for dropping by and have a great day.
