Strouty
I may have to stop reading this thread for a few months, we are just going into Fall and then Winter, I may just get jealous of all this talk Spring and Summer weather after the snow sets in!
Solar hot water... evacuated tube? Your day schedule makes me feel slightly lazyOf course, I'm about 3000km from home, so no home chores.. just business.
Seriously though, your thread is one of my favorite "***-kick" experiences here. Apparently you and Pope Francis also see eye to eye on the need for global sustainability![]()
Nice work 1/2 cup! I'm just starting a bit over a week off myself.
. Internet and Radio. At present I can count the listeners on one hand. Internet and Radio.
Have had no more feed back as yet on what went wrong with the broadcast after 9 am.
Still not giving up my day job and Eddie (who ran the control desk) and I agree the two fellow we filled in for for the two hour show do a pretty good job with the show.
Fantastic Solar weather the last few days so if you are having the days like we are here your power bill should be looking good (read as reduced).
Any updates on the other Solar system you are working on ? and are you still looking at the suggestion I gave you with the Solar Hot Water I use here ?
I do not like the mention of any BANGS. If it was me that Solar Panel would be set up making power for something else given I do not like the idea the system would produce Hydrogen. Looking good and looks like you have been very productive with the break away from work.
Great little rig you have started. I like putting the tank on a dolly. What is the conduit for? I assume it it holding the negative leads.
Looking good so far. From what I understand, the process does not produce all that much hydrogen. As long as you use it in a well ventilated area, like outside, as you are planning, there should be no issues with hydrogen build up at all. I think a charging battery produces more hydrogen than electrolysis due to the acids involved.
1/2: nothing better than having a sparky fine tune the Electrolysis methods we use. looking forward to seeing how your projects turn out. feel free to add any comments or projects to the homemade electrolysis thread we have on GJ and if there is a better thread or source for information please let us know.
good luck
.I am thinking it would be good for my fire unit project. May have to stick with the angle grinder and wire brush for that.
Impressive solar setup!!
I just had a thought ( I know that's hard to believe ) with the amount of solar you have and if you had a pool we could up scale my set up at your place and de rust the fire unit.![]()
maybe not
. Impressive how well those two items came up after.You guys laugh but they do it with welding machines and car/truck bodies. just need enough water and enough juice!![]()
sounds like good improvements, I found degreasing first along with brushing the parts or wire wheeling them about halfway through the process seems to help too. Definitely get that mill scale off and give it a shot. They say line of sight works better too, like having the bars up level with the center height of the parts but IDk, mine was vertical rebar all around so I didn't get to try that theory.
Wow,Cup nice set up and even better outcome.
With the strong sun here in Oz I recon you and Hot could derust the titanic,ggg
Great result!![]()
I have wanted to setup an tank for a while, now I want a solar one!
That was very impressive for only two hours.
Details on the anodes? They look constructed from the plates near the bottom of the tub maybe welded to pieces of tubing? Then with a bolt or threaded rod at the tube top for wiring attachment and a strap hook for hanging over the side of the tub? Anything I'm not seeing?
Wow! Great job 1/2 Cup! I'm impressed. Wish I got more sunshine up here in the middle of the woods...
1/2: awesome. also for huge items if you have any friends with property you can dig a big hole, put in heavy duty plastic (think pond liner) and fill with water and put in a car or whatever you like. of course if it's rusted too much the rust might have been holding it together.
thanks for trying this and with your knowledge i'm still learning more so when i set mine up i should have a system to last the rest of my life.
cheers 1/2 and nice work. are you painting or using BLO?
