Between 705 & 1200 SQ/FT A trip back from the edge.
X
xtremek
St. Johns, Mi
Yeah, little stuff I usually just plug. But we get all kinds of junk, big nails, pliers, scraps of metal. And usually when I get something, it's on the freeway. So by the time I get the car stopped, the inside of the sidewall is toast. I THINK I get a tire warrantied about every 1 1/2-2 years.
X
xtremek
St. Johns, Mi
A few months back, Robin hit a deer with the youngest daughter’s car. Fortunately, it only took out the headlight, which I picked up from Best Value Auto Body Supply for a 1/3 of what the local chain stores wanted. In order to replace the assembly, you have to pull the bumper, which isn’t really that tough a job. Did have to take it back out, because one of the pins in the assembly connector was pushed back in. Luckily, it was not locked in place, so a quick pull with pliers and it was good to go.'22 Bambi 1.jpg'22 Bambi 2.jpg'22 Bambi 3.jpg
jon72vega
Niles Michigan
Does anyone like to safety wire? When the weather was nice, I got the rag joint between the clutch and the trans finally installed. One, maybe two more evenings of nice weather (that’s not a Tuesday, Wednesday, or Thursday) and Claudia will be running again.clutch safety wire.jpg
We had a machine at work (a Bridgeport converted with a turntable to do production milling with an automatic part clamp/unclamp) that had a couple of bolts that had to be safety wired.
When the maintenance department would get done refurbishing it, I always was the "chosen one" to wire the bolts, cause no one else wanted to accept the responsibility if the machine bolts came undone.
racer-john
Newmarket, ON Canada
That safety wiring WON'T work. You have to constrain the bolts/nuts in the locking direction, and use the largest dia wire that will fit through the smallest hole. Sorry X.
X
xtremek
St. Johns, Mi
It is in the proper direction. At least I'm pretty sure it is. As far as largest wire, it sure isn't, but I'm not redoing it. We'll know soon enough I hope.
X
xtremek
St. Johns, Mi
it helps to think of finished safeties as art, but I will say I've worked on helicopters for the last 41 years and take pride on a well done safety
I won't call safety wire art, but doing it properly is definitely art work, if that makes any sense.
jollygreengiant
Ontario, Canada
If I was a betting man I'd say he got sucked into the bathroom project.
It's funny how whenever SWMBO starts a project that is stated to be exclusively hers that 90% of the time I get sucked into it at some point. I imagine that same phenomena exists for K as well.
sublime68charger
SW Wisconsin
you forget when said project goes sideway's you alway's get 100% the blame even if you said at the beging this is a bad idea lets just hire it done by the pro's.
X
xtremek
St. Johns, Mi
I have a total lack of motivation lately. On the bathroom front, Momma is chugging away at it. I have had to give her a hand once or twice, but for the most part, she's been handling it herself. She's done all the framing, the vent and drains, the cement for the shower base and step up, and roughed in the electrical. I did help anchoring the subfloor, but she did the mortar board. Weeknight have been about my class and getting caught up on homework (missing two classes killed me), weekends have been about running errands, so not much is getting done. I have got a couple goodies, so I need to get on the ball and write that post.
jollygreengiant
Ontario, Canada
I'm glad to hear I'm not the only one. The longer days usually helps but over the last little bit I have no ambition to do anything. It's probably not helping that a teething baby has really wrecked my sleep schedule. I made a list yesterday of everything I could remember that I need to get done this spring. Boy was that depressing. Now I remember why I don't use lists lol.
What classes are you taking?
X
xtremek
St. Johns, Mi
My issue is absolutely everything is a mess. Before Covid, the outside/property looked decent. The house wasn't great, but it was tolerable, and the shop was a work in progress. Now everything is a disaster. I've got to quit looking for motivation, and start finding determination. It also doesn't help that the current vehicle in the shop is my daughter's Equinox, and it has a bad
case of Michigan Cancer. And she adores her car.
The class I'm taking is CAD (Solid Edge). It's Tuesday and Thursday evenings, and church is Wednesday. I've been using Monday and Friday to play catch up. I'm learning enough to get me in trouble.
tj675
The Mitten
I absolutely hated it at first, however after being introduced to a good set of reversible safety wire pliers things changed.
jollygreengiant
Ontario, Canada
No pics, sorry. But my group at work needed someone who knew which end of the screwdriver (sawzall/angle grinder) to grab, so I got to cut the c-pillar off of a Cadillac Lyric. Not everyday you get to hack up a brand new $125,000 car.
I'm assuming there is a good reason to why they needed to take a sawzall to a brand new Cadillac?
X
xtremek
St. Johns, Mi
They need that piece to study its influence on antenna performance. On a side note, DO NOT EVER BUY Potter Cable cut off wheels. I made a roughly 14" cut in the outer skin of the Caddy and it was gone down to the arbor. On the other hand, the Milwaukee Demolition Sawzall blade cut through everything I tossed at it.
X
xtremek
St. Johns, Mi
That must have been fun to use a sawzall on that car, a video would have been great though.
It was a riot. But pics/videos aren't worth my job. The General takes those kind of things (pictures of cars not for sale to the public) very serious. They actually pay Google a **** ton of money to do constant web searches for posts of that kind of thing. Talking with the Executive Chief Engineer for the Camaro just before the current version was released and the Program Manager walked up. Seems some supplier employee posted a pic of the tail light on the internet a half hour earlier. 3 hours later, the employee was identified, located, badge confiscated, GM access revoked, and fired. Call me chicken, but I've heard similar stories so many times, I'll do a hard pass. Even if it's accidental, the outcome is the same, gone within hours.
X
xtremek
St. Johns, Mi
Shhhhh!!!!!!!!!!!!!!!!!!! Our Saturn is one of those as well. It had been sitting on campus for 20 years before I got it. But I didn't take the chance. I bought a wrecked Saturn and titled the school Saturn as the wreck. I just hope no one ever looks at the VIN tag.
