I was away for work for a week, came home and was greeted by the most awful smell. I thought at first I forgot to throw the trash out before I left, turns out it was the smell of a moldy living room rug. While I was away the AC handler in my attic decided to clog up in the condensation drain line. the pan over flowed because the drain line was not properly set up (how does something drain if you dont have it sloping downwards to you know drain out???) and now I have a 6ft W x 10ft L area I tore insulation and drywall out of my living room ceiling
Anyways, I called my HVAC guys as Im not well versed with HVAC stuff and they came and got line cleaned out. But now the issue is the following items (keep in mind my unit is mounted sideways for some stupid reason):
-Residual water that backed up in the unit and the insulation inside the unit is saturated to say the least. im not quite sure what to do other than mop it up. its NASTY and unless I take apart the unit and or cut the stuff out I cant remove it. Do they sell this insulation somewhere, maybe a similar product I could get? The HVAC guys are great, but they will only do so much I feel and replacing the insulation is a bit more than id like to pay them to do when its likely simple
-The drain pan frankly is junk. Im not sure why the ***** whom installed it, it it the way they did. The pan has a perfectly good hole in the side, but they put the hole in the center and hung the pan off the unit - again the handlers mounted sideways. I was thinking about getting a new pan, but then again the a/c shouldnt be leaking
I have the HVAC guys coming tomorrow to mount a shut off valve on there in case of a clog, but the insulation in the air handler i doubt is ever gonna dry now or will take forever. I was thinking to leave the unit off during the day as the attic gets very hot and open the side and maybe let it air dry. I cant put a fan there with no one home to monitor it just in case as Im at work all day
Thoughts?
Thoughts?
