Sorry for the long post again, TL;DR below!
This is somewhat of a continuation of my last post regarding adding some wrenches to my collection.
Background:
Home gamer, I currently have a Tekton standard combination wrench set from 8-22mm as my main wrench set. I don't have any SAE wrenches, I've gotten by with adjustables or SAE sockets. One or two of the Tekton wrenches are showing some very mild surface rust in some spots and I've noticed looser fit on some fasteners in some sizes over the years(comparing them to how sockets fit on those fasteners). It's never slipped or rounded a bolt, but it hasn't been confidence inspiring. I know I can probably warranty some of them, but just haven't seen the need to as they haven't actually given me an issue.
I use them for working on passenger vehicles(mostly Japanese or Korean) and bicycles for friends and family. Oil changes and brakes are what I do most for cars, but I also do more stuff if needed: radiators(just last week for a friend's 02' Camry), cv axles, ball joints, belts, alternators, valve cover gaskets, head gaskets, wheel bearings, etc. I don't work on any lawn mowers, jet skis, snowblowers, or anything like that... yet.
Based on some great suggestions from my last post, I went ahead and purchased a small set of non ratcheting zero offset double box end wrenches; I bought the KTC M1603 with 8x10, 12x14, and 17x19mm. I also picked up the Astro nanos 6-24mm and will be picking up the accompanying KTI43517 this month, to make a flexible reversible XL ratcheting wrench set from 6-24mm. It'll be sub-optimal due to the ratcheting wrench's head size, but I believe it should be plenty useful despite its size. I also plan to pickup the XL double box end Capri 13x15 and/or 16x18 as needed to add on to my KTC set.
Issue/Question:
I've been contemplating adding some long pattern combination wrenches to the set, but I'm thinking that they'd be redundant with less utility than the double box ends. I was looking at these Toptul AAEA Long Combo Wrenches or the Blackhawk 8 Piece 10-17mm. If I get the Blackhawk set, I'd add the Toptul AAEA 18 and 19mm.
Instead, I could "upgrade" my standard wrench set to a set of Toptul AAEW Standard Length Super Torque Combination Wrenches(which look very close to Mac/Milwaukee/Craftsman V/Facom/USAG wrenches) from 8-22mm and a maybe few common SAE sizes(1/4 - 11/16? since 3/4 is 19mm). The price should be pretty similar between the two options if I end up picking them up from Cryer Tool. Looking at around $100 for either option, probably.
I'm heavily leaning towards skipping the long pattern combination wrench set, upgrading my standard combination wrenches, and adding a few SAE sizes for when I purchase a home in a few years.
Thoughts/suggestions/comments?
TL;DR: Upgrade existing Tekton Combination Wrench set to Toptul Super Torque? Or add a set of Long Pattern Wrenches? I already have XL Double Box Ends, will be getting a ratcheting flex XL wrench set. Don't have a stubby wrench set, but will likely go for a cheaper set since they're low torque. Don't have ratcheting reversible combination wrenches, but will likely hold off on those for a while.
Background:
Issue/Question:
