Added Pics to mystery tool
DBSTools
Piperville PA
Ok, I added pictures,
Old barrel type ratchet tool that measures 10 1/2" total lenght. The top has a brown wooden knob attached with four screws. The working end has a slotted bit held in with one four sided bolt. I can find no makers marks.
Not sure what this is for. Anyone?? Before I open this up to see what gearing is inside.
I added another picture, this side as a threaded end that must have attached to another handle to rotate the working end.
Thanks much everyone for your thoughts (serious or not!!)
darkk
Willimantic, Ct.
I recently had an oil tank that had a 1 1/2" round threaded cover. It required a tool with an end that resembled a flat bladed screwdriver with a 1/4 round end about 3/4"-1" wide to remove it. The tool needed to have a rather large area/handle to apply pressure to unscrew it. I made something extremely close to this tool to remove that cap. Unfortunately I don't have any photos because I gave the tool away with the oil tank. So my guess is....it's a specialized screwdriver!:dunno:
Kevin54
MEMBER EMERITUS
Urbana, Ohio
What does the push button do? Does anything on the tool rotate or better yet reverse rotation when the button is pushed?
Steevo
43.49600, -112.04300
Lapping valves?
The "bit" would engage a slot in the valve face, so that a twisting action on the knob would rotate it against the seat?
1948
IL WI border
Lapping valves?
my thoughts exactly, im thinking it might have had a crank handle on the one side?
darkk
Willimantic, Ct.
Lapping valves?
Learn me something, not that it ain't so but, what type of engine has valves with a slot in them? I've had many types of engines apart and never seen one. Really...:dunno:
Big-Foot
Midlothian, TX
I thought of a valve lapping tool as well, but the only ones I have seen had a suction cup interface for the valve...
Curious....
Zrexxer
Pflugerville, TX
Most of the older crank valve lappers came with a flat blade with two prongs on it. Modern valves with smooth faces require a suction cup.
Big-Foot
Midlothian, TX
Interesting....
I have seen valves that had both slots and two holes in the head of the valve. Old Dodge flathead was one with the holes as I recall.. I just never knew what the holes/slots were for...
What exactly ratchets? or, id the "pin" on the side turns, what happens on the business end? Does it rotate, or does it "agitate" like a washing machine? (Rotate one way a bit, then the other?)
Nuts
Baker City, Or
Valve lapping tool, should use some form of a planetary gear system that reverses its self every couple of rotations. The knob on top lets you lean into your work. Nice one.
Nuts
