Adding a receptacle to a T12 ceiling fixture
rharman
SoCal
I'd like to add a bug zapper in my garage. I have a duplex receptacle in the ceiling but it's fully populated by my retractable extension cord and door opener light fixture.
I have 4 T12 8' fixtures in the main portion of my garage within reasonable reach of where I'd hang the bug zapper. Is there any problem in mounting a handy box & receptacle on a knockout on the side? I really don't want the zapper on 24 hours so having it switched with the light would be great.
Fixture similar to this. Hard-wired into a ceiling box.
u2slow
BC
Sounds reasonable. I'd do it in my own shop.
Edit: check the circuit loading. If it's maxed out, do something else.
dscheidt
Other than handy boxes are the mark of incompetent handymen, no. Almost all fixtures like that are listed as being used as a raceway. Even if it’s not, it’s allowed to extend the lighting circuit to another fixture.
R
rharman
SoCal
Here's an idea. Make the single duplex a two duplex.
Or just plug in a 3 way adapter.
Doesn't appear there's much load on it anyhow.
I used "handy box" as a generic term. I get that there's a stigma to them in some people's eyes but I'm not wiring a space shuttle here.
Not worth the effort to cut things up to put in a double gang box. And, that doesn't deal with the fact that I want it switched. A "smart outlet would resolve that but... overkill.
The adapter is a real simple fix but that means the zapper would be powered all the time. I'm trying to avoid that.
u2slow
BC
This (with a chase-****** or plastic grommet for the wiring) is what I was picturing, neatly on the end of the fixture.
dave*99
Coastal NJ
Your bug zapper is still going to be in the wrong place. Give it to your next door neighbor. That's the correct distance to be from those things for bug-free living.
^ Yes.
Position a bug zapper at least 20-40 feet away from people to draw insects toward the zapper rather than your gathering area. Place it in a dark, isolated location, such as a tree or shepherd's hook, to maximize its attraction, and away from competing light sources. The ideal height is 6-7 feet off the ground to be in the insects' flight path.
It's good to run the zapper for a while before you open the garage door.
R
rharman
SoCal
^ Yes.
Yeah, I do have a concern of attracting them right to where I'll be.
Neighbor has one on their front porch but it ain't helping in my garage. :cool:
I may just keep doing what I do now which is to use OFF spray or wipes to repel them.
Leaflessshadetree
Don't ask.
I have one in my garage. When the lights are off the bugs are attracted to it.
When the lights are on in the garage I don't hear many getting zapped.
ripperd
Twin Cities, MN
If you do this you should label the outlet as well. The wiring in those florescent likely is smaller gauge and if an unsuspecting person hooks up a true 15-20a load to an outlet on the end of them they are going to get hot and potentially also have quite a bit of voltage drop.
dave*99
Coastal NJ
You need connect to the branch circuit wires that feed each light. They should appear in every fixture. You should not tie a receptacle to any smaller gauge wires associated with each fixture.
R
rharman
SoCal
Don't forget that GFCI protection is required, & must be accessible.
Yeah, IF I do this, the tie-in would be to the feed from the recessed box. I believe its all 12ga Romex. Might be 14 but I doubt it.
Thanks for the reminder. Didn't think about GFCI. The existing ceiling outlet was 1993 so not GFCI.
