roofster
I have a home built in the 50's. There are no GFI's anywhere and most of it seems to be 2 wire circuits (no ground wire). I would like to start adding GFI protection to the usual places. I know GFI's on 2 wire are allowed, and in some places where the wiring is inaccessible its going to have to stay that way. In the unfinished basement where I could replace the wire, would it be better and worth it to run new romex with a ground wire? Or is a GFI without the ground good enough? The current cable in there is pre-romex, but I don't know what or how old it is.
The service entrance panel is in the basement and I thought that is where I would start updating the outlets. There are 5 120V outlets in the basement, 4 are one 1 circuit and 1 is on a separate one. One of the four is used to run the sump pump, another runs the water softener. I read about a GFI exemption for sump pump if it is a single receptacle. Sounds like a plan. Does the water softener need to be on a GFI protected outlet? I should add that all these basement outlets are in handy boxes, which leads to another question. From the handy boxes, there is 1/2" conduit up the wall to the wood floor joists and framing. From there on, it is cable run through the floor joists. Is it ok to run new romex in the conduit? I thought I saw where this was a big no-no, then I thought where I read it was OK. So I'm not sure. Also there are no clamps or bushings where the cable goes into the conduit, it just goes in. Is that per NEC or not? We bought this house earlier this year, and had it inspected first, but the more I read here and elsewhere the more unimpressed I become with his electrical inspection.
Finally, a little more info on the basement outlet wiring. It may be a multi-wire circuit, but I have not looked yet to see if the breakers are on different legs. One breaker controls 7 keyless light fixtures and another runs the 4 receptacles and one keyless fixture. 12/3 is used from fixture to fixture with lights being on the red wire. The 4 receptacles and fixture on the other the circuit use the black wire and each are fed using a piece of 12/2 from a keyless fixture. White wires are all tied together. One idea I had was to use a GFI breaker for the receptacle, but then the sump pump is on that unless its receptacle is re-wired somewhere else. Based on the answers above, it may be recommended to update to new cable with a ground wire.
If I do that, should I continue this multi-wire scheme or change over to complete and separate circuits? One day, we may want to finish the basement if that makes a difference.
A last question. Down the road, I'm considering replacing the 100 amp panel in my detached pole barn with a new 100 amp one. Would this need a permit or inspection? Would the work in the basement need a permit or inspection? Should I just ask a local inspector these questions?
I'm sure I will have more questions later on, but this is a good start.
Thanks All,
Thanks All,
