Adding leverage arm to motorcycle stand
TheClaw
Chicagoland
I'm looking for ideas to attach, on a temporary basis, an additional leverage handle on a motorcycle lift.
The lift I have is pretty cool. It helps me spin a bike around inside the garage. However, it's a little short and on my heavier kawasaki it takes a lot of heft to tilt it up and at the same time balance the bike.
I'm not a welder so I'm looking for a solution that provides the mechanical leverage I need and is removable.
The pictures show the stand with the bar from my Jack wedged in some of the corners. Anyway I can attach this with parts and bits from the home Depot?
The Pitbull stand is shown as an example. It's the red lift that I need to work on.
kngelv
Detroit, MI
The small wheels on that rear stand are your main issue. Just get another Pit Bull for the rear.
James
imagineer
Do you have a crow bar? Slip the hook end in the opening inside the loop and under the cross bar (where the "Grand Pit Stop" label is).
T
TheClaw
Chicagoland
That's a good idea. I thought flattening the end of an iron pipe then drilling thru the label and cross member so i secure it with a pin. What i don't want happening is the bar slips off to the side and then the whole thing topples over.
driftpin
Condor roller dolly
Yes it's costly, but easy to load/offload, and to roll-about. Watch the video.
The New Expandable Condor® Motorcycle Garage Dolly
Simply push any motorcycle onto the Garage Dolly and into the Condor® Wheel Chock. Its patented adjustable cradle accommodates every type of motorcycle — from heavy cruisers and touring bikes to sport bikes and dirt bikes — with wheel sizes from 13″ to 30″. Once secured in an upright position, your bike can be easily rolled, swiveled, or pushed anywhere in your garage for storing, servicing, detailing, or simply keeping it safe and out of the way.
The Garage Dolly rides on sturdy 4-inch wheels that navigate cracks, crevices, and uneven garage floors with ease. Built from durable aluminum and steel, it weighs just 68 lbs and supports up to 1,300 lbs. It measures 90″ long (expandable to 94″) with a 12″ wide deck and 24″ at its widest point at the wheel brackets. Four large twist-down brakes keep the unit firmly in place while loading or unloading your bike. When not in use, the Dolly folds flat and can be wall-mounted for storage.
The Garage Dolly includes a Velcro Security Strap (Part# VS-Black). The following add-on accessories are available separately: Supplemental Ramps (Part# GD-RAMP1-ASM and Part# L-PB35-C), Extensions (Part# GD-EXTEND), and Height Assist (Part# GD-H-ASSIST-KIT).
Proudly made by Condor® in America.
Smilodon
Titusville, FL
I also feel as mentioned before, I think your leverage on those little wheels is going to be an issue. Adding leverage with a long bar is going to be like a 3 foot breaker bar on a 1/4 inch socket, something is going to break. I've dropped bikes off of stands before, and it isn't a pleasant (or typically cheap) experience.
I have a Bursig stand similar(ish) to the sky lift @M.Brane mentioned. Not quite as cool (I never found skylift ones when I was looking way back when), but suits my needs. That said, these stands don't work for everything or on every bike but worth a look.
I did a little looking around and there seem to be some better designs for straight up multi-directional stands. At the high-end I found the Dynamoto stand (pricey), but even at the lower end, there is this one, which seems to have a little better thought out front wheel design.
My Bursig (not cheap)
Dynamoto stand (also not cheap)
Inexpensive "Speedmetal" design
T
TheClaw
Chicagoland
Found my solution, at least for the time being.
My great grandfather's old pipe wrench is getting put back to use. I can't say I have ever used this wrench. I have held on to it for 40 or 50 years since my great-grandfather passed and my grandfather passed. I inherited any of their tools that were worth anything. Just goes to show you never get rid of old tools.
