Garage is 28' deep by 36' wide. Ceilings are 10' high. Two 8x10 garage door bays. Ceiling is 5/8 plywood and will be painted light gray or white. I wanted to paint the ceiling black but wasn't sure how that would effect the lighting. The walls will be a light natural stain on the tongue and groove pine walls. The picture below is not actual garage but similar how I plan to do it.
I am debating between the deformable garage lights like the one pictured below or the typical 4' LED shop lights. I included the layouts of what I was considering below in the graph paper sketches. The red lines and circles represent where I had planned on putting the lighting. Most of the time my garage will be used for woodworking/construction projects but I also will occasionally do car repairs.
If I go with the deformables, I will be putting them on 3 different switches so I can control the lighting. If I do the 4' LED shop lights I will do 5 switches.
So here goes...
1. If I go with the deformables, how many lumens should I go with for each light?
2. Is 9 of the deformables too many for a 28x36 garage? If so, what would you suggest? Is my layout correct?
3. If I go with the 4' LED shop lights, is my layout adequate and is the number of lights correct? And what output should the lights be?
4. If I go with the 4' LED, should I go with neutral, bright, or super bright?
5. In your opinion, which is the best lighting choice and why?
Thanks so much for all your help!!!
Mike
So here goes...
Mike
