Advice on removing seized exhaust nuts
chicane
Central Virginia
I have 4 totally rusted and seized exhaust nuts that need to be removed. Two are accessible two are not. It is already a tight area to work in but I cannot get my Dremel tool much less my grinder in there. What I really need is some sort of then cutting attachment to snake in between the exhaust pipes in order to cut the nuts off. Does anyone have any advice on how to proceed with this?
bart1
Alabama the Beautiful
Dremel offer something like that. When I replaced the exhaust on one of my cars, I just cut everything off (and replaced with stainless).
lestat
UK
Soak them in wb40 and then invest in an Irwin bolt grip remover set. It took off exhaust nuts that were literally defaced by rust. Couldn't quite believe it.
signcrafter
There are lots of options but none are usually fun! Sawzall, cut off tool, torch if you have one, pb blaster and bolt grips, those small handle hack saws, etc. Sometimes you have to get creative.
Dave.R
Grand Rapids MI
I've had a ton of success with Deep Creep by seafoam. Its nice that it doesn't flash from flame, and isn't all over the place like pb. Works well for throttle body cleaning too. Its become my do all.
Dustin Echoes
Gagetown , NB Canada
^THIS^
Deep Creep is awesome stuff, foams up, and ***** itself into anything. Doesn't spread everywhere it isn't needed. I swear by it.
isaac338
Halifax, NS, Canada
Take it to a muffler shop. They'll do it quick, cheap, and easy.
If you won't do that, if they're on studs heat 'em red hot and get on them with vise grips. If they're on bolts, torch them off and replace them. If neither of those plans are doable, take it to a damn muffler shop.
C
chicane
Central Virginia
If I wanted to take it to a muffler shop I would just take it and not bother to ask a question on this forum.
regguy1
On Mount Olympus with Zeus
You can use an air chisel with a sharp bit to split the nut or cut off a section then just knock the rest off with the chisel or by hand. Use a careful touch with the air chisel
BWS
Mnts of Va
Just a FYI,theres times when you can't use a torch directly on a nut,for whatever reason?We've had good success with heating cheapo(disposable)impact sockets to glowing red hot and then letting them heat transfer to part.Usually takes several,quick...heat,soak,heat,soak...shooting with a infrared gun.
Not sayin it'll work in this case.....but it does work.
Shadowdog500
Down the shore
Where are the nuts rusted at? If it is the manifold studs where the exhaust pipe connects, heat up the manifold by the stud an use an impact to remove the nut and stud as one piece.
Then replace the stud and nut.
Chris
CORTEZSS69
Kansas City
I like using GM Rust Penetrant and Inhibitor. GM# 88862628, runs about $6.25 a can. If that dont cut it, time for the flame(torch). Good luck.
greasemonkey44
memphis
I will get one of these when money starts shooting out of my ***.
http://www.theinductor.com/
absolute best way to heat a bolt.
we have one at work; it is great
works well on freeing up locktited bolts as well
for exhaust work; i get nasty
usually a 1/2 impact and alot of kroil; then vice grips, bolt cutters, nutsplitter, air hammer, and finally a torch
vssjim
McLean Va.
I also have a 90 degee haed for my Dremel as I had to use it to grind out a broken off bolt in truck cyl head that was covered by the body kind of.
Tavy
Skip right to the torch. If you're reasonably skilled, you can split the nut in half without ruining the stud (granted, you should change the stud anyway. Mac stud removers.)
Otherwise you can notch the nuts and smash them with a hammer and chisel or any combination thereof, and soak with penatrant or diesel fuel (whatever's handy), spreads 'em a little. Have had good luck in the past.
If you break the stud off flush, good luck.
jdonahoe6
Are these manifold studs that you can't get out? I work in a custom exhaust shop and what we do is thread two nuts onto the manifold stud, hit it with either the Mini-Ductor or the torch, then use an 18 inch extension on an impact gun to zip the entire stud out of the manifold. For anything else we use the torch and a punch to get rid of the old nut/bolt combo and use new 5/16 or 3/8 stainless steel hardware
Also, make sure you have a good flex socket to get to the studs, asian and most german cars are a 17mm, american cars are either a 9/16 or 11/16
