advise on lean-to addition
hudsonman44
KCMO
Hey guys, just found this forum and am super excited about the wealth of information. We just moved into a house with a barn large enough for all of my hobbies/projects (gym/woodworking/welding/automotive), but I am needing to build a home office in the near future. One of the previous owners seems to have been a dog breeder, and built a 22x16 slab next to the barn (with doggie doors). I have seen gambrel barns with lean-tos, and am hoping I can build one on the left side of the barn, and inclose half of it for an office. the HOA regs say the outbuilding footprint can be up to 1400sqft, and inclosing the slab would bring me just under that.
My first question is about the slab. I'm not sure how thick it is (I'll drill a test hole once I unpack tools) or what kind of construction was used. There is cracking, and it doesn't appear the slab was tied into the barn slab, so I'm not sure if I can use this as a foundation, or need to break it up and have a new slab poured... any advice on this or tips on who to talk to?
After I get the foundation questions sorted out, I need to decide on the lean-to construction. The roof eave is at 13ft, and I've seen gambrel barns with lean-tos that start under the eave, so I'm thinking having the lean-to start there with a finished height of ~8ft should give me a 4/12 pitch... would that look out of place? With the roof construction, on a 16ft run, could I run 2bys from a ledger to the top of the outside wall for a vaulted ceiling, or should I use a truss for that length?
JDWVYoqFfgKqZuta9
wtjEKzUxGCJbUowEA
k5bX17k1YfrtGMy16
2wdCJR6fD7ugVcy78
Moss
Ontario Canada
Nice barn, looks a lot better than mine! The slab doesn't look great but not really terrible either. I don't see any relief cuts so i'd guess that's why it cracked. I doubt it's suitable as a "foundation" you'd have to drill and put posts up to support the outside wall I think. Then the concrete would serve as a "floor" If you are making an office do you have room for another small building somewhere instead of the lean to? You might end up being happier doing that.
Bobthetractor
Central Florida
I can’t tell from pics but looks like you’ve got vertical movement so not just from lack of a control joint. If it’s going to be an office (under air) rip up the slab and start over. Looks like it’s moved for whatever reason and I doubt it’s got a vapor barrier under it. You mention HOA. If so I don’t know how you’ll avoid it being to code and permitted. So trusses I would think are the way to go. I’ve never designed/built in the snow and I assume KC gets some?
Dig next to the slab and see how deep it goes. Could well be thickened edge so don’t trust that completely.
boxer259
Huguenot NY
seeing the horizontal and vertical cracks on the concrete tells me that there is minimal
reinforcing and the spacing from the barn wall indicates freezing water probably moved
the slab.This was not a contractor job.
