bd8134
I had my new Bendpak XPR10AC lift installed Friday, nice.
The problem is that the front arms, worse one side than the other, are rubbing on my nice Wolverine floor. I swapped the front arms from side to side with the pins, still the same. My floor is lower on the worst side.
With a level on the arms when it is resting on the stop, the 'bad' side is about 1/2" down which has thin shims, front and rear arms. When they installed the lift, the fastener bolts are about level if not just below the fastener nut. So putting a thicker shim under the baseplate does not seem possible with the present fasteners not having much meat left.
I was considering making up a shim / washer to go between the carriage and arms. Using shims and washers, it looked like I need 0.4" on the worst side to stop the arm rubbing on the floor.
Sources for these shims? About 1.5" hole, 4" diameter.
Any suggestions?
Any suggestions?
