Affordable 3/8" Torque wrench?
atwageman
NC
I've got the the HF ones in all 3 sizes. They are ok. Nothing spectacular though. I really want something by Snap on / CDI. In the meantime I ordered a digital one from Eastwood yesterday.
http://bit.ly/1h2I8vZ
Aquaticbob
Seattle
I own both the 3/8" and 1/2" torque wrenches from Cman. I like them both a lot. I also believe the 3/8" is in inch lbs and ft lbs if I remember correctly. The click style is nice and it stops you right on the mark every time
jmm
NC
If you're using them only a couple times a year, get the HF ones. They're a killer deal. They're reasonably accurate, repeatable, ridiculously cheap, and you can trade them in no questions asked whenever you want. I've had one for years for home use. With minimal care mine is still accurate; I keep it in it's case, use it for it's intended purpose only, work the spring out before use and set it to the bottom of the scale while it's sitting. I check it out against my digital SO at work whenever I need it for more than lug nuts and it's held up just fine.
signcrafter
Get the Husky at Home Dept. $74.99 and the same as the gearwrench sold else ware for more. Also looks VERY similar to the Matco for $300. I have the 3/8 and the1/2(84.99). Oh any made in the USA
http://m.homedepot.com/p/Husky-3-8-in-Click-Torque-Wrench-H3DTW/202916179/
I never even thought to check HD when I bought my torque wrenches. I bought a gearwrench 1/4" torque wrench and really like it but paid 90 bucks for it from tooltopia. Looks just like the 3/8" you linked to.
cburnscrx
Indianapolis
G
GoodEnough
Don'y worry, I will patiently wait to find one for only $225 at a garage sale.
I'm thrifty like that!
HF is $21.99.
What coupon gets it down to $9??
ez-duzit
Marina del Rey
Some are too poor to buy anything but the cheapest available. Don't be that guy. :p
Avoid the crappiest of imports. Much better to buy a quality used tool in excellent condition.
kippieland
Western Washington
Any of the Taiwan are good (like the HF.) Nothing great but work. I have some CDI's and freakin love those things. But cost is higher. There really isn't a middle ground...its either cheap or expensive.
skeletonizer
I have the C-man you linked to as well as a C-man ½" in ft.lbs. They get used monthly maybe more. No problems so far. Would buy them again if they are still US made.
The only pics I have of them are when they are in the long gray boxes they came in hanging on the peg board.
todd_fuller
A local tool surplus place has a box of 3/8 CDI torque wrenches for $15 for 100 ft-lbs. versions. Might be worthwhile to check around or on eBay.
nicksnothereman
In the Mojave
nicksnothereman
In the Mojave
I have the beam-style 1/2" Craftsman and for only occasional use, it works great. If they make a 3/8" version, I would recommend it.
Kev
It's chinese now. Still, um...works.
I don't agree with the "it won't fit assessment" that some people have on here. Usually, it will fit!:lol: The only thing that's a potential problem is the "dial plate" (the numbers and pointer) because it's wider than a traditional clicker.
Brownsfan
Cleveland Ohio
That's because it's the same one. There is a Matco one that's even more expensive that's the same
Danglerb
SoCal
Bought mine on sale for a total around $35 set of 3 HF. Good chance I will borrow SO Techangle when I build a motor.
Farmall450
Marengo, Illinois
Beam style seems like it won't fit into small places.
It's actually slimmer till right at the handle.
spin_prod_665490301
Steinmetz
Washington State
I think Goodenough was referring to the swing necessary when using a beam-style wrench. There are ratchet adapters that may be used on beam-style torque wrenches that at least partially eliminate this problem.
SMKS
USA, planet Earth
There's a 3/8 CDI (10-75 ft-lbs) wrench at Epsteins for $50 (http://store.harryepstein.com/cp/MiscInventory/CDTW.html). I bought one from them and like it a lot.
I also bought this CDI from HE. It has worked well for me, although the head seems on the thick side. I think the Husky/Armstrong/GW/Matco head seems thinner.
They are super old stock. Mine has a date code on it that appears to be 1989. But it works well and it's in spec when checked with my torque adapter.
akrafty1
I picked up 2 Proto wrenches from flebay. A 0-80 and a 50-250. Both were a steal. The 50-250 was new and had never been used and was $60. The 0-80 was in need of service so I sent it off to Proto for calibration for a total cost of $50. Not bad for 2 wrenches with calibration certs and cases... Oh, and these dang things are freaking solid.
