Aids for Lifting Heavy Items
Thegundog
Virginia
My last son just moved out, 3 hours away, which makes my wife and I empty nesters.
I'm pretty involved in mechanical repairs typically having multiple projects going on: classic cars, small engine machines, tractors etc……
A couple of days ago I needed to rebuild a carb on a generator and realized I no longer had help (since my son moved out) lifting the machine onto the bench and ended up having my wife help me.
My back no longer likes me lifting and I’m pretty conscientious about it……
Anyone in a similar situation(?), and if so what kind of creative ways are you employing to lift heavier items in the shop with no help?
Crabman
Alexandria, VA/Dameron, MD
gundog,
First of all congrats on the empty nesting and welcome to GJ. I too am being careful with the back, etc.
There are few threads on this issue, it depends on how your shop is set up and how much you need to lift. Maybe a search for hoists or gantry will pick some up.
My recollection about one that appealed to me a guy set up a pickup crane so it would lift onto his bench.
Good luck finding a solution that fits your needs.
Bruce
laser3kw
northen IL
my arsenal:
engine cherry picker
hydraulic lift table (30"x20")
pneumatic lift table (motorcycle / lawn tractor)
hand winch
ratchet straps
I am also considering a jib type hoist to attach to the pneumatic lift table to assist with repairs on lawn equipment.
NUTTSGT
Northern Central Ohio
Sweetcorn
North Central Ohio
I don't know what your workbench set up is like, but I love this thing. The table is extremely heavy, but i did the hydraulic jack and caster mod, so it moves easily whenever i want it to. I use it all the time for my home shop. In the first pic I'm lifting a crazy heavy smoker out of my truck.
Before anyone loses their minds, I know that isn't a lifting strap. I lifted the smoker up a couple inches, drove the truck out, and set it down. Its all my stuff and I was willing to take the gamble.
finn
The UP, God's country
Lifting straps that run behind your neck are inexpensive and invaluable. They save your back. They’re available at Menards and probably Lowe’s and HD.
An engine stand and a couple of chains and slings. Get a load balancer for it.
A come along is handy, especially the ones with a chain or strap.
Tractor and skid steer with a bucket and forks
Mini excavator rounds out my lifting tools.
niget2002
Josephine, TX
2 ton gantry. Kinda a pain rolling it around the shop, but it gets the job done. I need to replace the I beam with a longer one as the current one doesn't fit over the wheels on my trailer.
Oh. I forgot the motorcycle lift. I just got it last year and have honestly used it more in the fully up position as another work bench. But I have used it a few times to get something in/out of the truck.
Renegade1LI
long island ny
I have an adjustable aluminum gantry, 10’ between posts so it’s great with my dually and trailers, height is also adjustable. As others have mentioned i have a hydraulic table from hf, engine hoist, mc lift and a pick up crane that goes in the receiver, really works great. I also have a prime mover used for masonry work, it’s a walk behind fork lift, just needs some work. I plan on adding a winch in the pick up bed to work with ramps. There are lots of affordable options out there.
gregs
I bought a used Genie type manual lift. Will raise to 12'. Use it like a manual forkilft to pick things up and also to get to things on some small pallet rack shelving. Handy to have.
TractorJeff
Elkhorn, WI
Got an engine hoist that is rated 3000lbs in the fully extended mode(Industrial rated). It takes up floor space because it is not foldable. But lifting tractor parts its safe! Skidsteer is an invaluable assistant also! If I could do it over, a hoist on a trolley beam would be in the budget!
Jagmandave
Overland Park, Ks.
I bought a 1000lb capacity hydraulic lift table from Harbor Freight for $200 - thing is heavy as hell, but it's on casters and has a handle to use to move it around. It goes from about 3" to at least 35" which is just slightly higher than my workbenches....this thing is so handy as I can roll it up to the back of my car and slide something right in or out.
I use it to build engines (small 4 cyls) and transmissions as it's easier to work off of than the bench since I can walk all around it.
Highly recommend one!
All of the suggestions above have merit, but I have a very small shop so I'm both space and height constrained, and don't have the room for a gantry or a forktruck.
YMMV.....
Renegade1LI
long island ny
You can also make a gantry, couple 4 x 4 posts and a beam, make it knock down or on wheels. I made one when i set my lathe up, couldn’t fit the aluminum one i have. I used a 3 x 8 length of ipe , but a steel or aluminum i beam would work, double 2 x 12 with a 1 ton chain block, just a thought and it’s low cost.
