startup amps 24.4, this is not going to be the instantaneous inrush, which would be a lot higher.
It will run at 21.4 until the pressure builds, then will rise to about 24.4 at full pressure.
# 10 should be good as long as your far from breaker box, if you want more info google "#10 wire capacity".
Been running a 30amp breaker for 5hp units
