Everyone's main air comp problem seems to be moisture. I just started using my new Eaton 5HP (with automatic drain), hooked up to my copper pipe system (designed by suggestions from previous posts). Have been using it for a few days, and I an not getting ANY WATER. I know this doesn't sound like a problem, but am curious why this is happening. I'm located in NY, not in some dry desert, and there should be water either in the main tank, my water seperators, drain tubes, etc. The pipes run about 90 feet, so there is plenty of cold pipe for water to condense. Any ideas?? Thanks
