Air compressor condensate drain on/off switch
2xs
So getting ready to install wiring for t30 Ingersoll compressor with an auto time condensate drain with and contactor for the motor and I'm going to add and on/off switch to my contactor being my compressor shares a wall with my master bedroom closet. So what I'm thinking is buy my wire with a third leg so I can run a neutral and hook my condensate drain into my contactor on/off switch so the drain isn't going off all night when compressor isn't running. So good idea bad idea or am I jut over thinking this ? I just don't want my wife to kill mainly if the compressor kicks on in the middle of the night and when the auto drain goes off every 45 minutes all the time.
2xs
Yeah I'm thinking about try not spend more money then I have to.
LS6 Tommy
Northern NJ
If you're not going to allow the auto drain to work 24/7 your defeating it's purpose. You might as well just manually drain it.
Tommy
2xs
I'm overthinking it for sure but I don't want the auto drain waking my wife up every 45 minutes or she is going to be one pissed of sob in the morning if see doesn't kill me in my sleep.
offroadsteve
Hampton, VA
I think its a good idea. You'll need the neutral, and you'll need a fuse for inside the contactor enclosure to protect the 120V portion of the circuit for the auto-drain.
marinusdees
Edgewood, Washington
Buy a cheap 24 hour timer and set it to go off at noon or?? No brainer. Auto drains work on pressure shift and go off anytime. Ask my son how I know Or he knows..
