Alright Guys,
I know this post has been beaten to death a hundred times but I'm in the same perdicament
. Which Air Compressor to go with? Currently these are what I'm down too.
1. Husky 30-Gallon Portable Electric Air Compressor
http://www.homedepot.com/Tools-Hard...splay?langId=-1&storeId=10051&catalogId=10053
2. Campbell Hausfeld® Portable 20 Gallon Cast Iron Air Compressor
http://www.tractorsupply.com/campbe...le-20-gallon-cast-iron-air-compressor-3301586
3. Kobalt 1.6 HP 30-Gallon 155 PSI Electric Air Compressor
http://www.lowes.com/pd_221495-1498...br|0||p_product_qty_sales_dollar|1&facetInfo=
4. Campbell Hausfeld 1.3 HP 20-Gallon 200 PSI Electric Air Compressor
http://www.lowes.com/pd_340269-4365...br|0||p_product_qty_sales_dollar|1&facetInfo=
It needs to be semi-portable so that’s why I'm straying away from the stationary ones. I'm partial to the Oil-Lubed ones for the longevity of the pump life (I know to be debated) and the noise issue. I also like the idea of a vertical tank for space considerations. I know the most important thing to consider is what I will be using it for so in a nut shell here’s what I was planning on doing with it:
General Automotive Care (Inflate Tires, Cleaning, etc)
Woodworking – Some Framing Applications (Hence the semi-portability); Cabinetry Projects;
Automotive Projects – Occasional ½” Impact and 3/8” Ratchet use; Some Air Chisel and Die Grinder work.
Other than that nothing too special. I won’t be doing any painting as I know my limits and I will leave that up to the pro’s (or people with patience) I value y'alls opinions and especially look forward to any hands-on experience y’all might have with any of these compressors. Also if y’all have any pictures of your current air system set-ups that would be useful as well.
THANKS IN ADVANCE
. Which Air Compressor to go with? Currently these are what I'm down too.1. Husky 30-Gallon Portable Electric Air Compressor
THANKS IN ADVANCE
