Sorry to
but I have been searching and reading on here and am coming up with more questions than answers. I recently got a 60 gallon compressor and would like to put the correct filters on. I'm ready to order whatever I need so I can get it installed asap so if you guys could help me design what I need that would be great!
The compressor has a max psi of 155 and there is a 3/4" outlet to connect to. So I understand that I need to run piping at least 25 feet from the compressor before I ad the filters. Do I run 3/4" pipe from the compressor to the filter? Then should I reduce to 1/2" or 3/8 filters? The hose reel that I have is 3/8 but I'm not sure if I should keep the line as large as possible up to it?
As far as brands it sounds like Wilkerson or Norgren are good brands to go with? Are new filters easy to obtain and replace as they get old and used? And do I want an auto drain or manual drain? I live in Minnesota so it gets cols here and my garage is only heated when I am out there so I don't need it freezing and getting damaged.
My main use is impacts, ratchets, air gun. I have never painted but may try a little in the future. What would you guys order if you were me? I'm sitting here with my credit card
but I have been searching and reading on here and am coming up with more questions than answers. I recently got a 60 gallon compressor and would like to put the correct filters on. I'm ready to order whatever I need so I can get it installed asap so if you guys could help me design what I need that would be great! The compressor has a max psi of 155 and there is a 3/4" outlet to connect to. So I understand that I need to run piping at least 25 feet from the compressor before I ad the filters. Do I run 3/4" pipe from the compressor to the filter? Then should I reduce to 1/2" or 3/8 filters? The hose reel that I have is 3/8 but I'm not sure if I should keep the line as large as possible up to it?
