OK Now that my compressor is functioning I would like to know the best place to install the water separator/filter. Directly off the tank is the shut off valve, then comes the pressure regulator.Where is the best place to install this item? The line coming from the compressor is 3/4 then through the shutoff valve ,then it is reduced to 1/2 for regulator then it is reduced to 3/8th for the rest of the trip.Should I have to worry about vibration from the compressor?Should the filter be as far from the air source as possible?Thanks, Ken
