Looking for feedback and ideas about what you used/recommend for plumbing a whole-shop air distribution system. (I did several searches on here)
I’ve looked at:
Black steel pipe
Galvanized steel pipe
Rapid Air system
Copper
Pex. **I don’t think Pex is truly up to the job but I sure wish it was.
My idea is to run the tubing in the ceiling trusses and behind drywall. Then place drops through the ceiling around the shop.
Any tips/ideas/feedback/photos appreciated....
Black steel and galvanized steel seem like they are easy to install, but I would discount them on the basis of rusting. I haven't done the numbers, but they seem to be economical.
Rapidair seems expensive, but so does copper.
Everyone seems to design their systems by setting an arbitrary size for the main line and then adding a bunch of drops. As sberry has mentioned many times, this tends to be overdoing it.
I can see a main line needing to be used for a very large space, just to get to all needed locations. And I can also see how a large system could benefit from looping. But sberry's idea about simplifying has much merit. He uses a whip, mounted to a boom to cover a large area.
The OP give no information about his space or needs, so all we can offer, and all he asked for, is suggestions for materials.
My own setup is very specific. A small one car garage stuffed with machines and some outlying sheds and other locations that could use air. The way I will design it, is to locate machines, determine their needs, and work from them, back toward the compressor.
In a small space like my one car garage, a hose reel mounted on the ceiling could serve all locations in the garage, but instead of having to hook and unhook from each machine or location, it would help to have some fixed connections. So the next step is to specify these fixed locations and size the supply needed for them. So make a list of all the needs for air. For instance, these are mine.
Compressor
Blast Cabinet
Painting Location
Plasma Cutter
Bridgeport
Hose Reel
Outside Outlet Garage
Outside Outlet Side Sidewalk
Work Bench
Carpentry Shed
Air Dryer
Since some locations are distant, main lines are needed. Another solution is small compressors either fixed or portable.
Bill
