Stuart in MN
Not saying PVC is safe, but that is the very definition of anecdotal
You selectively omitted the rest of my post.
I've run systems in several of my garages over the years. I'm a backyard mechanic that likes to do things "right." I paint occasionally and use quite a few different air tools. What I've learned, for my needs, is the following:
1. I love the attached design and it's what I base my set up on. I don't run a dryer, but I'd like to at some point. I also don't run a looped system. Mine is dead headed.
2. I've always run 1/2" copper, but in my new garage I'll be running 3/4" at least for the main feed and then 1/2" drops.
3. I would NEVER run black pipe. I had a 12" piece in my system temporarily
for a while. When I went to remove it, it had a bunch of rust scale inside. No thanks...
For,those that don’t want to thread black pipe or solder copper, look at Prevost.
I wish I would have bought a couple 100 ft rolls of 3/4 to do my long runs. I am way up in a ceiling, black is a pain in the rear and super slow, would have been done in a day vs a week with no leaks.For,those that don’t want to thread black pipe or solder copper, look at Prevost.
https://www.prevostusa.com/#
They make their own fittings and their own pipe. Pipe is aluminum with exterior coating. This helps with cooling. No connection is permanent. All are torqued to their specs and can be undone at anytime. For those that want a super dry system, look at the tapping flanges that come our the side of the pipe. Super easy to cut with a pipe cutter and just deburr.
I installed in would do it again. Adding to this system is super easy compared to black pipe and copper.
How does one love the attached design and not like anything about it or the features that make it what it is?1. I love the attached design and it's what I base my set up on. I don't run a dryer, but I'd like to at some point. I also don't run a looped system. Mine is dead headed.
How about Sharkbite fittings with copper pipe?
Bill
Yes, you mentioned it earlier in this thread. But where do you get it? And how much is it?
