kapster
I have a twin cylinder single stage Campbell hausfeld 60 gallon compressor I bought used. Since I've hooked it up, I get a bit of oil in the airlines. It makes the coupler oily, corroded my filter/ regulator bowl some. If I don't use it for a week or so, I get a puff of musty, oily smelling stuff out the air hose.
My local compressor shop said thats not right and said to take the head/ valve plate apart. If nothing's wrong there it needs rings. not sure I buy the valve plate making it use oil?
So is this normal with an oil lubricated compressor? Should I work on it or get a coalescing filter? I mostly use it for blowgun and running air tools. I'd like to use it for my sandblaster and painting occasionally. If a coalescing filter is the answer, use it for everything or just paint and sandblast?
Thanks guys
Thanks guys
