air compressor oil drain rerouting
My2boys
Edmond, OK
My oil drain on my compressor is in a bad place. I was planning on using some pipe and move it to a better location. The only pipe I can find that is the size I need is galvanized. The question I have is will the gaovanized pipe be ok with the oil in the compressor.
Thanks for the help
My2boys
Edmond, OK
K thanks, I didn't know if the galvanized coating would come off and hurt the bearings or something.
BirdRacer
If it's for the drain, the old oil and any galvanized coating that might come off wouldn't drain back into the motor would it?
dirttracker18
Slate River, ON
That's what I was thinking.
I have the same issue and I was thinking of adding a ball valve and then extending the pipe out.
It's not like there are people screwing around in my garage that might let the oil out. It's up high so kids can't reach it and it would make it very convenient.
Any reasons not too?
EOC_Jason
Bentonville, AR
I've seen quite a few compressors come from the factory with a ball-valve coming out of the drain, then a short piece of pipe, and it still has a cap on the end (just in case).
BrianC636
Republic, Mo
I'll snap a picture of what I did on mine tonight. Basically, 1/8" to 1/4" pipe adapter (pump to valve) then a 1/4" ball valve, a street 90 then a 4" ******.
I can slide a hose over the ******, route the house into a drain pan and walk away.
I don't see any reason why you couldn't do this.
BirdRacer
How do you figure?
Well, I said motor, but obviously I meant pump.
I guess the way I was looking at it was, if there is any flaked off galvanized coating in the pipe, when you drain the oil, that gets flushed out the pipe. Normally the drain doesn't angle downhill towards the pump, so the old oil/crud shouldn't be draining back towards the pump. If that was a concern, I would bend the drain pipe slightly downward.
Gary S
Bismarck, ND
Galvanizing isn't a problem. What you do need to be aware of is that extending the drain with a rigid pipe makes it more vulnerable to metal fatigue and failure from vibration of the compressor. I would recommend using some kind of flexible line that won't suffer from vibration.
PT Doc
Does anyone have photos of a factory installed oil drain setup?
rlitman
Long Island
Good point. If you're extending the drain a few inches, this won't matter, but if you're plumbing the drain a few feet, this can be a real problem.
EOC_Jason
Bentonville, AR
Most I've seen people just extend them a few inches, maybe a ball valve (which I think it a little overkill)... From there you can just stick a piece of vinyl tubing on the end and let it drain into a container... No need to go all crazy, it's not like people are changing their compressor oil monthly...
NewShockerGuy
Northern Virginia / DC
I did this a while ago with my oil compressor... Gives you an idea, but makes the oil changes much easier and pretty much zero mess....
Pretty much used an 1/8 npt ball valve. Used the little pipe extension and then put a cap on the end just in case there is a little leakage but there isn't anything that ever leaks.
Works out very well.
-Nigel
jonathan75
NC
Burgerkong
Markham, Ontario, Canada
I like the short handle. I picked up one at HD but it has a long handle. The one you found is more subtle. Is it WOG?
This one looks good too. It only cost more then the pump.
http://www.ferguson.com/FergusonSearch/RecordDetails.action?R=PROD_327755&search=true
Negative. Their smaller mini ball valves are not rated for oil or gas. I am thinking of replacement the giant handle with something smaller. If won't get in the way regardless since there's around 8" between the edge of the mounting bracket and the pump drain.
I have seen a member on here plumb one into his Quincy though, identical to what I want to do, I swear I saved the picture somewhere but I can't find it.
EDIT: It's not a Quincy, but it's your buddy with the SB clone pump: http://www.garagejournal.com/forum/showpost.php?p=3187785&postcount=1735
http://www.fordmuscleforums.com/other-articles/477599-air-compressor-maintenance-drain-valve.html
http://garagejournal.com/forum/showthread.php?t=196406
I'm pretty sure HD sells a Watt's valve that is WOG rated.
jonathan75
NC
I think I will stick with my HD valve. It is WOG and looks well made. The Zoro one looks a bit rough.
