Air Compressor Oil
Matt M PA
SE PA
Well guys, I figure it's time to change the oil in my compressor. It's a 2 Stage/80gal Sanborn that I've had for many years.
According to the manual, it uses a Sanborn 019-0053SP. Looks like that was disco'd a long time ago.
There are specs in the manual, but no weigh listed. The list flash point, pour point..and viscosity of 525SUS 100F & 65SUS @ 210F. None of this helps me.
Can I just go to Lowes or Home Depot and buy their compressor oil...or....?
tncatadjuster
Memphis, TN
I have used mobil 1 10w30 in mine for 20 years, I'm sure someone will say no, but it works fine. That is what the dealer that sold it to me said to use.
sberry
Brethren, Michigan
Yes, that is about as good as any. If it's not full of water and clean to start with, a few years old already a change to a synthetic comp oil, Amsoil is super good, can be good for the life of the unit in common comp under typical home/hobby use.
sberry
Brethren, Michigan
I have a pump I bought 20 years ago, near 2 grand at the time, still has the original oil, I will never change it. My shop unit runs daily, last change was 10 years, still crystal clear, won't do it again unless I need to work on it.
TRWham
East Cobb County, Georgia
65 SUS at 210F is SAE 30 or ISO 100.
isb cornbinder
Specialized compressor oils are offered in the brand to match many compressors. A good information cheat is to look up the product in the MSDS. The details compared against a main brand of oil will help to make a choice less stressful.
Skin
Boston
I don't see any point in synthetics. Consumer compressors tick over at 1k or below at a constant rate, don't have corrosive combustion gasses, don't get nearly as hot as an engine, and don't benefit off the additive packs. Its a solution to a problem that doesn't exist. The only argument that can be made is if its an outdoor unit and you wanted better start up protection during winter.
JAKES.
Sandwich, N.H.
Hi, i would chek to see if your unit likes detergent or not. At my work they changed the oil in the pump with oil with detergent and seals failed. IMHO synthenic oil is worth the $$ for severe duty cyles. -Jake
JAKES.
Sandwich, N.H.
If I may double down here. Oil viscosities break down over time losing their friction resistance. I just want to pass along useful info I have learned the hard way! - Jake
seber
Deep East Tx.
Generally speaking, motor oil should not be used for compressors due to the detergent additive which will cause carbon buildup. Valves and regulators don't like that.
sberry
Brethren, Michigan
Synthetics are better hot as well as cold too. When one figures in the service life are cheaper. Another thing here is the small volumes, doesn't add significantly to the cost, extra 10 or 15 dollars over a decade doesn't mean much.
