Hi I just purchased a 33gal quiet Husky air compressor model C331H . I have been reading lots of threads about compressor driers so I am building one. I took the line that connects the piston to the tank off and am trying to find some fittings that I can use to attach some kind of flexible pipe (copper, air brake line, hydraulic line etc in place to route to my drier. The end of the line that I took off that connects to check valve/tank (picture with crescent wrench) looks like a compression fitting, but the fitting that connects to the piston has a high temp oring that sits in a groove on the line and then a small cap that screws on. I dont know if I can use a normal threaded connection and no oring because it does not look like there are many threads, but maybe some sealant would make it work? This line looks like it takes about 165psi and from what Ive read could get quite hot ~300F? Hopefully these pictures will add clarification. Any help is appreciated Thanks!
